Power Brake Booster.
Old Dec 21, 2022 | 09:48 PM
woodsmoke's Avatar
woodsmoke
I had to replace brake booster on my 1966. Now I'm picking my teeth out of the steering wheel. Even with careful application of brake pedal when it catches it hits hard. Not so before. A mechanic at shop I use said his Dad had one like that and he put some kind of reduction valve in vacuum line going to booster. Any one have experience with this situation? Thanks.
Old Dec 22, 2022 | 11:46 AM
William's Avatar
William
Using the tool, adjust the booster to MC rod. There should be a vacuum valve between the booster and intake. If you don't have one you need to install one and if you have one replace it.
Old Dec 25, 2022 | 11:28 PM
woodsmoke's Avatar
woodsmoke
I did adjust rod between booster and brake pedal to get right adjustment. There is no vacuum valve between intake and booster. That is what I was inquiring about. Is there a specific unit that I need to acquire. Thanks.
Old Dec 26, 2022 | 11:13 AM
William's Avatar
William
Google "brake booster vacuum valve". Your power brake system must have this valve installed in line between the vacuum source and the booster. They are available at all parts stores and online. Usually cost less than 15 bucks. After replacing the vacuum valve if the problem persists replace the brake booster. There is also the possibility that your brake pedal ratio is incorrect if you added a booster to a non boosted system? This can be corrected by mounting the brake pedal to booster rod lower on the brake pedal. Moving the pedal mount will lower the pedal closer to the floor where it belongs in a power brake system. I had this issue some years ago and I resolved it by drilling a new hole in the brake pedal and lowering the brake pedal mount. Google "brake pedal ratio" for a more detailed explanation.
cwesner227
1983 - 2012 Ranger & B-Series
Sep 9, 2014 12:55 PM
400M_Bronco
Nov 15, 2012 04:24 AM
dooger
Jan 17, 2011 01:24 PM
dagray3
Dec 20, 2008 07:11 AM
philipwhite
Aug 16, 2006 08:06 PM
