Sponsored by: Real Truck
Damn spark codes
Old Apr 10, 2021 | 11:52 AM
ja.mc44's Avatar
ja.mc44
Damn spark codes
Yo guys,
2005 5.4 triton throwing p0358 code. Truck when I bought it was throwing three of these spark codes, so I put in new coil plugs and sparks but this keeps seeming to pop up for cylinder C. Any ideas where this is coming from?
I checked injector with test light and was get the pulsing light while truck was running so I'm assuming not injector... where to go from here. Is this going to be an issue with a driver in the cpu? Think I should take it to a shop to hook up a fancy reader get some readings? Thanks.
Old Apr 11, 2021 | 06:06 AM
projectSHO89's Avatar
projectSHO89
"Cylinder C" is #3. If you have a fault there, you should be getting a P03X3 code where "X" is either a ) or 5, depending on the type of fault.
Old Apr 11, 2021 | 09:07 AM
kcducttaper's Avatar
kcducttaper
I got sick of my '99 5.4 misfiring and replacing those stupid plugs all the time. I swapped in MSD 'Blaster' coils and iridium plugs and haven't had an issue since.
Old Apr 11, 2021 | 05:12 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I dont see how because ANY spark plug or COP other than a real Motorcraft will throw codes or go bad on these trucks
Old Apr 11, 2021 | 09:03 PM
projectSHO89
Well, since the ALL of these trucks left the factory with those parts, I guess then there would never be any need to ever replace any of those parts (except for routine/scheduled maintenance) if your statement were to be correct.
roughridn_sob
2004 - 2008 F150
Dec 18, 2016 07:05 PM
phinfan1016
15
Jun 7, 2015 10:43 AM
FFEMT32
Modular V10 (6.8l)
May 10, 2013 07:31 AM
omegalita
Jan 30, 2012 07:06 PM
socalexpy
1997 - 2003 F150
Jun 4, 2007 04:07 PM
