Backup camera problems
Old Dec 21, 2022 | 01:37 PM
Madmacs61's Avatar
Madmacs61
2nd Gear
I replaced my backup camera and wiring harness in my 2014 F150 to the camera. With the original camera I was getting the "camera not available " message. So I replaced it and the wiring harness to it. New camera, now the video is scrambled. Any ideas?
Madmacs61
Old Dec 27, 2022 | 06:12 PM
Tom's Avatar
Tom
Welcome to FTE!
I'm sorry that I didn't catch this sooner, but you posted in the F150 Lightning EV forum. I'm moving this down to the 2009-2014 F150 forum. You should get some better responses over there.
Old Dec 27, 2022 | 06:30 PM
paredneck33's Avatar
paredneck33
Don't quote me on this, but you may need to have the new camera programmed to your truck. But first you could start with double checking the connector on both the truck side and the tailgate/camera side for damage or loose fitting connections. Also inspect both harnessed for damaged wires. (i.e. cut/frayed insulation on the wires) Also be sure to inspect all ground wire locations for looseness or corrosion. If that all checks out you may need to make a trip to the dealer to have the camera programmed to the truck. If nothing else they most likely will need to calibrate the camera so that you can see proper distance on the screen.
Brian Ski 44
2014+ Transit
Aug 7, 2021 10:56 PM
BayStYat
Jan 24, 2020 01:43 PM
Jghake
13
Jul 2, 2019 03:27 PM
JRB64
Aug 4, 2017 10:41 AM
sokojoh
Bronco II
Jul 12, 2002 06:39 AM
