Flywheel/Clutch Mating Issue
Old Dec 19, 2022 | 06:30 PM
sdwilliford23's Avatar
sdwilliford23
4wd Low
Good evening, guys!
I searched the threads and found an old post where someone had this same issue, but I didn't see a resolution. I've got a 1973 F-100 Custom with a 302 and manual 3 speed toploader. I'm not sure what the motor came out of, but it's a 1980 I believe. The transmission is original as far as I know. The flywheel had some cracks so I ordered a new flywheel and clutch kit (lever style).
The new flywheel is the 164 tooth, 14" wheel (which mates up to the existing starter nicely). The clutch I have is an 11" clutch. However, the hole drilled in the flywheel only fit an 11" diaphragm type clutch (we had one to try) and what would seem to be a 10" clutch.
I can't find a flywheel that I can be sure will mate up to the 11" lever style clutch. Anyone know what to do here besides order a diaphragm clutch? I'm outside my window to return lol.
Thanks everyone!
Seth
Old Dec 19, 2022 | 06:36 PM
kenny nunez's Avatar
kenny nunez
Clutch bolt pattern
Take the 2 flywheels to a machine shop and have the new one drilled and tapped for the new clutch.
Old Dec 19, 2022 | 06:49 PM
sdwilliford23
4wd Low
Thanks for the quick reply. I guess since the mounting will be symmetrical, this won't mess up balance?
Old Dec 19, 2022 | 07:42 PM
kenny nunez
Flywheel
Just be sure that the new flywheel has the same balance weight as the old one.
FuzzyBeanBag
Oct 20, 2021 09:33 AM
Dedmonds101
Sep 22, 2021 01:40 AM
Hit Man X
Aug 20, 2018 03:00 PM
dieselsubmariner
Jan 10, 2015 12:09 PM
BIG J82
Jan 11, 2012 07:53 AM
