Take the two spider gears out, and through them away, then weld the side gears to the case. This way you can get more penatration into the case, and a longer bead. Strengthwise, a full spool is stronger, but a lincoln locker is cheaper.
I put a Trac-Lok in the front Dana 44 but I will weld my rear 8.8 Ford. You say to not use the spider gears and just to weld the side gears to the case? Will the heat welding cause the cast iron case to crack? What type of welding rods should I use? Any tips? I plan on doing this ASAP.
