400 New Build Cam Selection
- Ford 400 bored .030 over
- Tmeyer -13.3 cc pistons
- Trick Flow 195, 72cc heads
- 1.73 Roller Rockers
- Roller cam and lifters (TBD)
- Compression 9.76:1
- Edelbrock Performer 400 intake
- Edelbrock 1406 600cfm carb (I may change to the Eddy 650 AVS)
- Long tube headers
- C6 Transmission
- Hughes 1,200 RPM F43FUEL Converter
- 1977 F150 2wd, 6,300lbs
- 3.00 rearend
- Lykin Motorsports - 211/214 @.050", 111 LSA, 109 ICL, Gross Lift .562"/.588", 7.8 DCR
- Crower Cams - 205/213 @ .050", 112 LSA, Lobe Lift .287"/.301", Gross Lift .496"/.520"
The number implies a deck height of 0.006'', which is fine.
Can you post up the advertised durations for both cams, and the ICL for the Crower ?
That will help to check the DCR of 7.8 on the Lykin, and calculate the DCR of the Crower.
Assuming the Crower DCR is acceptable, I'd be inclined to choose that cam. The higher LSA and lower lift would provide a smoother idle than the Lykin, although maybe negligible.
The overall choice of parts is good.
The one thing that catches my eye is the 3.00 gear ratio. Would that be too sluggish off the line ? (I don't know.)
Make a note of this :
A cooler spark plug will be required for the increased compression. One or two numbers lower.
The total mechanical ignition timing will drop from +/-36* to +/-30* due to the more efficient combustion. (Idle timing can be as advanced as the engine likes.)
A shift kit in the C6 would be beneficial, and assuming the tranny is out, it's a breeze to fit.
I believe stock manifolds provide more torque than headers, but I've never confirmed it personally. (Headers sound nice though.
)What I listed for the cam recommendations from Lykin and Crower, is all I received. I can send both an email and see if they will provide the advertised duration, and ICL on the Crower.
I was a little concerned with that high of lift on the Lykin. I filled out cam spec request forms for Lunati and Comp Cams, but no response from either. Since the Lykin and Crower specs are different enough, I thought I better get some additional advice.
I thought about changing the rear gears, and I may eventually. However, I'm not going to be racing my truck, and with no overdrive, the 3.00 gear are nice on the highway.
I'll make note of the plugs and timing info. 👍
When I had my C6 rebuilt several years ago, a shift kit was installed at that time.
I have had the long tube headers for a long time (see pic below). However, I never liked the 5/16" flanges, and nobody makes any thick flange long tube headers for a 351M/400 2wd, so this may be a good time to change to a shorty header, like Sanderson.
Fitting a piston and measuring the actual deck height is the correct way of doing things.
Fit all 8 pistons and measure all 8 deck heights.
You never know, cylinder one might be 0.006'' whereas cylinder 8 is 0.002'', for example.
If that were the case, 0.002'' would be the number required to estimate the DCR with a given cam. (0.002'' would up the compression to 9.84, for info)
I wouldn't be concerned about the higher lifts on the Lykin cam, but I would be curious. (Generally, roller cams have significantly higher lifts than the Flat tappet hydraulic cams).
You could always ask each supplier, via phone, why they chose the numbers they did, and then consider their answers.
It didn't occur to me that you already drive with 3.00 gearing.
Seeing as you are about to have more power and torque, you'll be more than happy with the existing gearing. (I'd love to have 3.00 gearing for the highways.)
I didn't realize that you have headers either. Maybe a machine shop could CNC cut preferred flanges and swap them in ?? (Nothing wrong with shorties though.)
Here's some more notes :
Piston ring gaps differ between the different materials used, so make sure to follow the instructions when gapping them.
Likewise, different honing grits are used, so ensure that the machine shop used the correct grit. (Maybe a bit late to do that now.)
Consider the stall on the torque converter. The OE level was something like 1,500rpms, and could now be raised to +/-2,400rpms. (The cam guys should be able to comment on that.)
I'd want a mechanical timing range of something like 16* - 30* to maximize performance, but I'm not sure that you can customize the Duraspark to that extent.
You can consider using fully synthetic engine oil especially as you'll have a roller cam.
Regularly check that the filter is clean in the valve cover breather, and that the pcv valve is 100%.
It looks like your vacuum advance is connected to ported, try full manifold at some point and compare.
I will be mocking up all pistons to verify deck height for each.
I do plan to reach back out to Lykin and Crower for additional info on the cam specs.
I will be gapping the rings per the specs on Tmeyer's site.
The machine shop wanted the rings so they could balance everything, so hopefully they utilized the correct grit for the rings.
I have not yet purchased the torque converter, so I could go with a different one if something else would better fit my application. I will see what the cam manufacturer would recommend.
I'll need to see what's doable for the factory distributor. I do not plan to change it to an HEI.
I understand roller cams do not require breaking in, but I thought it was not a good idea to utilize synthetic oil on an engine which is not broken in, due to rings not seating in correctly. Is that not correct?
I'll look into the vacuum advance port connection.
6 by 8 I appreciate all the good info.
I will be utilizing a custom grind, which is why I contacted Lykin, Crower, Lunati, and Comp so I could get their recommendations for a custom grind. The bad thing is that Crower has no blanks and may not have any until mid 2023. Lykin has only billet blanks, which I may end up with, unless I want to wait longer.
Assuming it is the OE low compression version, you're in for a very nice treat with a higher compression, correctly designed, 400.
I'm impressed that Lykin gave you a DCR number, and 7.8 would be a safe limit for using 91 octane gas. (For example, very hot weather would not induce detonation a.k.a. pinging. At 8.0, say, it might.)
Haha, no, you don't need to change to an HEI, and even they aren't that easy to get dialed in 100%.
When you start to dial in the timing curve, and 'feel' the differences in performance whilst driving, you'll know what I mean about dialing it in 100%.
Try and find the time to do a bit of reading up on the following :
Mineral versus semi-synthetic versus fully synthetic engine oil.
Duration at 0.05'' lift. (There's a reason both cam suppliers are offering you cams in the 205 - 214 range.)
Duration at 0.006'' lift, a.k.a. advertised duration (Without these figures, a cam cannot be wisely chosen. Period.)
(As an example, here's two cam specs. One would not work. But look how similar they are !
204/214 @ 0.05'' - 282/292 @ 0.006'' - LSA 112 - ICL 109 - lift whatever
204/214 @ 0.05'' - 262/272 @ 0.006'' - LSA 112 - ICL 109 - lift whatever)
Lobe separation angle (LSA). You've been offered 211 and 212. 210 and 214 would also work.
Intake centre line (ICL)
Lift
Your existing torque converter can be rebuilt by a 100% proficient professional. Hmmm, that said, they are becoming rare these days.
When you install your cam, use a dial wheel to 100% confirm that the cam timing is EXACTLY what the cam card states. (And of course the cam card must be EXACTLY the same as what you were told at the time of ordering the cam.)
Fit a new Melling, or equivalent quality, oil pump and oil pump shaft, and good quality block plugs, during the rebuild.
Consider EZ or Fumoto drain plugs for the block and C6. (Life is soooooooooooooooooooooooooooo much easier during oil changes.
Lift
)From reading other timing related threads on this site, I'm sure I'll spend a lot of time getting the timing dialed in. I'll definitely use your advice for starting points.
I'll do some reading on utilizing synthetic oil for a new engine. I would prefer to use synthetic once the engine is broken in, I just need to make certain it's okay to use during break in.
I have no idea if there are any shops around my area that rebuilds converters, I would probably just buy a new one.
I will be utilizing a degree wheel for the cam.
I have a Melling standard volume pump on order, it was backordered, and is planned to ship early January.
I'll definitely look into the suggested drain plugs.
There are several off the shelf cams, available now, that would suit your needs just fine. (The above 268H wouldn't be one of them if its part number is CL32-221-3.)
That said, we've been talking about hydraulic roller cams until now. Are you totally averse to a flat tappet hydraulic cam ?
Your concern is certainly warranted, but your fact finding/opinion seeking will/should ensure that your concern never materializes.
Your desire is to have an engine that provides the torque etc as outlined in post one, but it's also to have an engine that will be mechanically trouble free for 250,000 miles (say).
