Upper intake manifold replacement (time?)
Old Dec 12, 2022 | 01:56 PM
mcd1978's Avatar
mcd1978
4wd Low
Anyone know how long this will take? doing it myself on Saturday. I am planning on 3-4 hours?
Old Dec 13, 2022 | 07:04 AM
Byoung Oh's Avatar
Byoung Oh
1-2 hours should be enough if you have right tools and watch some youtube video. You will not be able to see behind manifold, so you need to just feel around it.
Make sure you run knock sensor wires above IMRC rods.
Skip through engine replacement video below and just watch intake manifold removal and installation part.
Just realized you have 4.6. It will be a little different, but looks like it will be easier than 5.4 and there is no IMRC to deal with and have more room. I think you still have to take alternator out to remove it.
Old Dec 13, 2022 | 08:04 AM
mcd1978's Avatar
mcd1978
4wd Low
Yeah, i cant get it out without taking the alternator off. I'm waiting on the part. I have been leaking coolant. I took thermostat off and in the housing there is a bulge in the rubber gasket causing coolant to flow out of the thermostat housing. Such a small fix but i have to replace entire manifold.
Old Dec 13, 2022 | 06:33 PM
Byoung Oh's Avatar
Byoung Oh
Was it only leaking externally, or did it leak into intake as well? If coolant got into intake, it can kill catalytic converters as well.
Old Dec 14, 2022 | 10:16 AM
JoeBillyBob's Avatar
JoeBillyBob
4wd Low
if you have a wife and/or kids, I would plan on the better part of the entire day⚽️
catto95
May 21, 2019 08:50 PM
scoony
Aug 28, 2007 09:40 PM
