Another crazy mpg question
Old Dec 9, 2022 | 10:18 AM
superdupery's Avatar
superdupery
I noticed the power fold mirrors will let you fold them in while driving, which surprised me. When driving on an open, deserted stretch of highway, does anybody fold them in for better gas mileage? Or maybe tot doesn’t impact enough to be worth it?
Old Dec 9, 2022 | 10:23 AM
acdii's Avatar
acdii
I experimented once, would take thousands of miles to see a difference of .01.
Old Dec 9, 2022 | 10:27 AM
ToMang07's Avatar
ToMang07
Sounds like a great way to get in a wreck.
Old Dec 9, 2022 | 10:40 AM
scraprat's Avatar
scraprat
Top Answer: 5
Depending on speed they might not open up untill you slowdown.
Old Dec 9, 2022 | 10:59 AM
HRTKD's Avatar
HRTKD
Yeah, I've done this. Usually in Wyoming when I'm fighting a 40+ MPH headwind. There's nobody out here to need to look for. It's not like I'm going to be passing anyone when the speed limit is 80 and I'm only doing 70 (towing). Does it matter? When towing, probably not. When not towing, it's probably not enough to worry about, but it does cut down on the wind noise.
My mirrors don't extend wide enough to see the trailer tires, so if that's what you're keeping the mirrors out for, it won't work for me.
Old Dec 9, 2022 | 11:22 AM
CheeseheadFord's Avatar
CheeseheadFord
Can't see your trailer tires with your mirrors? How's that? I can see down the entire side of my 38 ft TT with my mirrors extended out and don't forsee a TT or any trailer where I couldn't see otherwise....
Old Dec 9, 2022 | 11:27 AM
acdii's Avatar
acdii
Whats funny is this same question came up way way back when gas prices rose up over $4 a gallon a decade ago. Thats how I found out, it doesn't make any difference worth doing it because been there, and actually done that.
Old Dec 9, 2022 | 11:31 AM
NedFletcher's Avatar
NedFletcher
While I would generally agree, I find it really useful if I get stuck going down a narrow road and I see another big truck coming my way. Nice to pull the mirrors in for a minute or two to avoid both of us losing 1k+ mirrors.
Now hypothetically thinking, if it did make a real difference and you were cruising down the highway in the slow lane, AND you could turn your 360 cameras on to show what's going on to either side, might not be horribly unsafe to keep an eye on that and then pop the mirrors out if you think you might need to make a move between lanes.
BUT you never know when a jerk is going to come out of nowhere, cut you off, and then slam on the brakes. If you have barely enough time to react you won't have enough time to put your mirrors out, check for car in next lane over, then move over to avoid a wreck. Happens to me a lot where some small car cuts me off only to slam on their brakes and turn off the road, so I'd never have my mirrors in while driving for anything longer than for a single oncoming large truck to pass.
Old Dec 9, 2022 | 11:39 AM
99powerstrokedF250's Avatar
99powerstrokedF250
What's interesting is that, while it doesn't seem to make a difference if they're in or out...on my Power Wagon it DOES make a difference if they're folded up for towing or down for normal driving. It's about a 1.5 mpg difference. Believe it or not, folding a Ram's mirrors up for towing adds a TON of frontal area to the truck that Fords' just don't gain by extending out.
Sorry, just a little tidbit.
Old Dec 9, 2022 | 11:52 AM
Monoman67's Avatar
Monoman67
That's the most noticeable impact. This is one of the reasons why some manufacturers have looked into using cameras.
Old Dec 9, 2022 | 12:54 PM
HRTKD's Avatar
HRTKD
Toy hauler. Wider than the truck. Tires don't stick out from the trailer.
Old Dec 9, 2022 | 01:06 PM
cat-alac's Avatar
cat-alac
Only at night if a set of obnoxious leds in my ***, because ford is too cheap to make outside mirrors dim.
Old Dec 9, 2022 | 02:36 PM
Keokie's Avatar
Keokie
I know. I hate that. Years ago I started aiming my mirrors out to cove the blind spot. I find it more valuable for visibility and it will take the headlights of the car directly behind you out of your side mirrors.
Old Dec 9, 2022 | 02:50 PM
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
I do remember back in the day (early 90's) when guys would lower tailgates, or even remove them, for better mileage. I did it once on my 4 cyl S-10, and it did boost a 1 or 2 mpg on a highway trip.
Old Dec 9, 2022 | 03:40 PM
Bananasfoster's Avatar
Bananasfoster
Hahahaha I experimented with this once between Sweetwater and Lubbock. (Thought I was the only weirdo that thought about such a thing)
122 miles of flat boring terrain and wind turbines
Mirrors out headed there.
Mirrors in headed back.
Zero difference in mpg
