3–Speed Transmission Locked Up
3 – Speed Transmission Locked Up
Pride comes before the fall. I, a retired band director/administrator, rebuild my ’53 flathead V8 and it purred like a big cat. Y’all answered two questions about the tranny, a hole where the shaft pin was leaking fluid and the tranny not shifting into neutral.
Took the truck out for a test run. Going around the corner, the tranny locked up. The sleeve over the synchronizer hub was stuck on the 2nd gear. When I was checking the neutral question I did notice that that sleeve did not move smoothly over to the 2nd gear.
I was able to get it ‘unstuck’ and have attached three pictures. To do that I removed the two snap rings from the main drive gear and it is slightly pulled out. The three pictures show the sleeve over the main gear, over the synchronize gear, and over 2nd gear.
The sleeve does not move smoothly to either side but particularly over the 2nd gear.
3-speed light duty three on a tree.
Looking forward to advice.
Last edited by HoraceFord; 12-08-2022 at 11:03 AM. Reason: To add pictures I forgot
The following users liked this post:
Edit: the shop manual does call them 7116's
Thanks. Where does that spring go?
In the drawing, the 7116's look like they have a groove on top of them. I do not see a groove on mine and I can't see a spring. They slide to the side with the sleeve (7106).
I reckon my option is to take it apart and see what it looks like. Since I've got to replace the 1st and reverse gear (7100) and the cluster gear (7113) (Yikes on the cost of that one).
Thank you again for the help!
Howard
Howard
Lots o' sparklies in that oil!
The spring is inside the hub, can only be seen when apart. The struts have a rounded bump in the middle on the top. The outer sleeve has 3 grooves on its inside that the bumps lock into, to hold the sleeve in place.
You can gauge synchro blocking ring wear by measuring the gap to the adjoining gear, as shown below (courtesy of Van Pelt Sales)
