Sponsored by: Real Truck
Help identifying part and leak issue
Old Dec 8, 2022 | 09:32 AM
markls's Avatar
markls
5th Gear
Looking for the name of this trim piece between window and cowl. Is this two pieces, or did mine split?
Two questions. See the above picture. What is the part name/number of this trim piece that is bowed up. This goes between the front window and the cowl, but I can't find a parts diagram that has this. Also, is this a one piece part (and mine has split since it the 1999 original)? Does this part also help prevent rain/water under the cowl and possibly leaking into the interior?
Leads to the second question/issue about the cowl. I'm finding water after it rains on the passenger side of front floorboard. Fortunately I have Husky liners that catches most of the water... but obviously it's coming from the passenger side and leaking out under the dash/glove box area. I've heard maybe a clogged drain or that there is a "hole" under the cowl on the passenger side that easily collects/allows water in.
Any help appreciated!
1999 F350 V10 - Crew cab, long bed 4x4
Mark
Old Dec 8, 2022 | 09:53 AM
62fordF250's Avatar
62fordF250
I'd call it a cowl seal or hood to windshield weather strip. Sorry I don't have a part number.
As for the leak, your drain under the cowl is probably plugged and water is coming in the fresh air intake.
hodge5
Jul 14, 2022 09:08 PM
dbc001
Mar 31, 2022 07:28 PM
cityjack
Dec 31, 2015 08:48 PM
twiztedford
Sep 3, 2009 06:30 AM
Ford4dog
1997 - 2003 F150
Apr 4, 2009 04:44 PM
