P1554 Code help
Old Dec 7, 2022 | 09:06 AM
purplewg's Avatar
purplewg
P1554 Code help
So, I have been getting the P1554 code CEL for a while. When I clear it, it will not come back on until I run the truck (over 100 miles), stop and as soon as I restart it the CEL P1554 shows up. Truck runs flawless. I guess my question is, is this truly a failure or could it be a connection problem? I have a Launch Pro Elite programmer and accord their web site it shows it can do the IQA change but I have not been able to figure out to get into the right area to find it. I chatted with their tech support and they guided me to the capabilities but nothing on instructions. lol
I need to try and repair this myself as my nearest dealer is a long drive and I don't trust them anyway. Any help for this old man would be appreciated. I am not a rookie at mechanical work or diesels. I have kept all my tractors and my 2000 7.3 running for years. Thanks
Old Dec 7, 2022 | 09:31 AM
speakerfritz's Avatar
speakerfritz
was curious so I googled itMake:FordCode:P1554Definition:Cylinder 4 Injector Circuit Range/PerformanceDescription:This DTC sets when the output of the fuel injector circuits are not within a calibrated limit.Cause:
  • INJ4 circuit open
  • INJ circuit short to ground
  • INJ4RTN circuit open
  • INJ4RTN circuit short to voltage
  • Damaged fuel injector
my comments...I had a 6.4 once that had injector codes so bad that it wouldnt start. I opened the engine bay fuel filter and poured a bottle of injector cleaner into the filter housing...re-install. then did a key on and off about 10 times. then started it. after the sound of someone droping a tool box went away...the engine ran fine.
so...have you tried injector cleaner?
best wishes.
Old Dec 7, 2022 | 11:01 AM
purplewg's Avatar
purplewg
  • INJ4 circuit open
best wishes.
No I haven't tried injector cleaner. I keep an algicide in the fuel but that is about it. I can sure try that though.
Just funny if I clear the code I can run it till I shut it off, next restart it will throw code. Their description makes it sound like it is either shorted, open, or shorted to voltage. To me that would throw a code most all the time. lol Will toss some injector cleaner in it and try that first. Thanks
Old Dec 7, 2022 | 04:22 PM
purplewg's Avatar
purplewg
Update! I just changed the oil in the truck for the first time. I had a maintenance package on it till now. Changed the oil and it took 14 quarts to bring it to the full mark even after letting it sit to drain down. I see most people say it only takes 13 quarts which is what my 7.3 takes. Anyway, started the truck the CEL went right out. The injector fault went away. I thought the 6.7 injectors were piezo fired. Are they still pressurized with oil like the 7.3L?
Old Dec 7, 2022 | 04:24 PM
speakerfritz
no not pressurized with oil
keep an eye on it.
Old Dec 7, 2022 | 08:29 PM
purplewg's Avatar
purplewg
keep an eye on it.
Will do. I am still confused. lol
Old Dec 11, 2022 | 09:01 AM
purplewg's Avatar
purplewg
Just another update. I took the truck into town about thirty miles. The code did not come back until I shut it off and went to restart it. CEL came back on. lol
Old Dec 18, 2022 | 07:16 PM
senix's Avatar
senix
you can try some diesel kleen and see if that helps. Bet the injector is bad
sandyc
6.7L Power Stroke Diesel
May 30, 2018 12:21 PM
micmoslof
Feb 23, 2013 09:24 AM
IQof3
Jan 8, 2012 07:25 PM
SkySkiJason
Jan 7, 2011 02:40 PM
Mscales
Computer Chips & Tuners
Nov 6, 2004 01:40 PM
