dash lights
Old 11-13-2003, 11:11 AM
cbeaur's Avatar
cbeaur
cbeaur is offline
dash lights
I can not seem to locate the problem with my dash lights not working. The bulbs are fine the wiring seems to be fine as well, is there somewhere else I should be checking before I lose my mind?
EDIT:
Truck is an 89 F350
SORRY
Old 11-13-2003, 11:43 AM
GeneStoner's Avatar
GeneStoner
GeneStoner is offline
FUSE?
Old 11-13-2003, 12:11 PM
cbeaur's Avatar
cbeaur
cbeaur is offline
It's not the fuse already checked that
Old 11-13-2003, 01:40 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Have you turned the headlight switch **** to maximum ?
Old 11-13-2003, 03:11 PM
drunkenmonk's Avatar
drunkenmonk
drunkenmonk is offline
dash ground?
Old 11-13-2003, 03:15 PM
cbeaur's Avatar
cbeaur
cbeaur is offline
Dash ground? Help me out here, I know what grounding is but not sure what you mean here
Old 11-13-2003, 03:19 PM
drunkenmonk
I've had the most confusing problems caused by a loose strap from the dash to ground
this wasn't on a ford, but I'd still make sure all ground connections were good first
Old 11-13-2003, 04:31 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,730 Likes on 1,400 Posts
Also this part of the headlamp switch could be burnt out.
