Sponsored by: Real Truck
5.4l P0443 code?
Old Dec 3, 2022 | 10:01 PM
woody367's Avatar
woody367
5.4l P0443 code?
My 04 F250 5.4l had a P0455 code so I took off The EVAP purge valve off and blew air in the port. One way no air came out reverse it and air flows. I put power to it and no clicking so I am guessing it is bad. I put the old one back in and cleared code. Now the light comes on with P0443. I checked plug connection and cleaned it but code came right back. Should I just replace the purge valve? Moorcroft is over $100+ just do not need to waste money this time of year if not necessary. Thanks
Old Dec 5, 2022 | 02:58 PM
user 195474726373's Avatar
user 195474726373
I think a bad fuel cap will give both of these codes.
Old Dec 5, 2022 | 05:29 PM
projectSHO89's Avatar
projectSHO89
It could only cause the P0455.
The P0443 is an electrical circuit fault in the purge valve's control. Could be an open coil or some an open/short in the wiring to the valve or internal to the PCM.
It would be a good idea to simply check the resistance of the valve's coil first to see if it's open. Should be a few dozen ohms.
Old Dec 5, 2022 | 05:35 PM
user 195474726373
Isn't it possible that with a bad gas cap a signal will not be sent to the purge valve?
Old Dec 5, 2022 | 05:54 PM
user 195474726373
Old Dec 5, 2022 | 06:58 PM
woody367's Avatar
woody367
I already replaced it with a motorcraft gas cap and that was not the problem. I did order a new purge valve today we'll get it by next Monday. When I want to test it with the power probe it kept coming up with a Dead short so I am gathering the valve is bed. I guess I will see when the new valve comes. Thank you
Old Dec 5, 2022 | 07:07 PM
projectSHO89
No, it isn't. That's not how it works.
Old Dec 5, 2022 | 07:08 PM
projectSHO89
Highly suggest you follow my previous recommendation....
Old Dec 30, 2022 | 05:51 PM
briguy87's Avatar
briguy87
1st Gear
I have the same code P0443. what's the ohms reading suppose to be 3-5ohms, 2.5 to 7ohms??
Old Dec 30, 2022 | 06:19 PM
woody367's Avatar
woody367
I put a new Motorcraft purge valve in and all is good now.
Notplayn
6.4L Power Stroke Diesel
Jan 10, 2014 08:12 PM
pile_53574
Jan 8, 2014 11:50 AM
pablocruz69
Aug 13, 2010 12:50 PM
fixnair
Electrical Systems/Wiring
Aug 11, 2010 11:45 PM
