Gas Gauge
Old Dec 3, 2022 | 10:01 PM
Huskerconan's Avatar
Huskerconan
4th Gear
Gas Gauge
Recently purchased a 55 f100. The truck is in good shape just trying to fix a few small things. One is the fuel gauge. Goes to full when started. Original 6v system but was changed to 12v. Will I get the same reading with voltage changed? Kinda planning on replacing sending unit but wondering if I need a new 12v or original 6v. Thanks Cliff
Old Dec 3, 2022 | 10:40 PM
Scottydog1001's Avatar
Scottydog1001
I had to replace my fuel sending unit going to 12v.
Old Dec 4, 2022 | 02:45 PM
sik9d1's Avatar
sik9d1
Trailering
Where the gauges swapped out for 12 volt versions or a 12 to 6 volt converted used on them?
Old Dec 4, 2022 | 03:32 PM
Scottydog1001
My gauge was swapped out also.
Old Dec 4, 2022 | 04:49 PM
sik9d1's Avatar
sik9d1
Trailering
You can use a 6 or 12 volt fuel sender. The sender is just a potentiometer and sends the correct ohm signal to the gauge. Just make sure the the sweep on the sender meets the same as the gauge wants to read full or empty correctly.
Old Dec 4, 2022 | 04:54 PM
Huskerconan
4th Gear
Not sure if gauges were swapped out. How would I go about figuring that out? Thanks
Old Dec 4, 2022 | 05:02 PM
sik9d1's Avatar
sik9d1
Trailering
Is there 12 volt going directly into your gas gauge or there some type of 12 volt to 6 volt step down?
Old Dec 4, 2022 | 06:35 PM
Huskerconan
4th Gear
have not metered anything. Be a week or two before I get to it. Will be back with info. Thanks Cliff
Old Dec 4, 2022 | 06:49 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
My 6v-12v conversion used the 6v gauge and sending unit and read correctly.
Old Dec 5, 2022 | 06:46 AM
Huskerconan
4th Gear
thanks for the info. Thinking its the sending unit just looking for others experiences. Thanks
Old Dec 5, 2022 | 07:24 AM
Greg Rogers's Avatar
Greg Rogers
My "56" has a 55 tank and sender. When I put it all together with 12 volt dash/gauge for 56 it works!! so I would just try it and see, may work fine.....
66f100restoration
May 2, 2019 08:03 AM
swoosh1958
Jan 31, 2017 03:45 PM
JackClancy
24
Apr 20, 2013 09:47 AM
Ron 51
May 9, 2008 11:16 AM
NormH
Mar 21, 2007 11:59 AM
