Gas Gauge problem
Old May 7, 2008 | 05:48 PM
Ron 51's Avatar
Ron 51
Arrow Gas Gauge problem
I am having a problem with my gas gauge. It was not working at all so I grounded it better and it went up. When I shut the truck off it goes down but it never comes down when the power is engaged.
All the other gauges work fine. I plan to take it out but don,t really know why it is acting up??????????????????
Old May 8, 2008 | 09:22 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Could be a lot of things. Is the gauge and sender original or aftermarket? Are they a matched set?
Old May 8, 2008 | 08:00 PM
Ron 51's Avatar
Ron 51
They are original.
Old May 8, 2008 | 10:51 PM
Julies Cool F1's Avatar
Julies Cool F1
The gauge is at the grounded end of the circuit. There is a rheostatic contact inside the gauge that allows a certain amount of voltage to flow to ground.
If you have grounded the sending unit, it's going to read full all the time. Chances are if it never read at all, either the float is full of gas or the sending unit is bad.
I'm assuming you still run a 6 volt electrical system.
Later Juls
Old May 8, 2008 | 11:15 PM
Bob at warsaw's Avatar
Bob at warsaw
Hi Ron
Is it a 51 6volt system
Old May 9, 2008 | 05:24 AM
Ron 51's Avatar
Ron 51
Yes it is a 51 6 volts system right now... I will take the float out and check it to see if it gas logged.
Old May 9, 2008 | 05:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
01A-9202 or 01A-9202-A .. Float / Fits cars & trucks 1940/1956 (1957 and later is smaller and won't work).
I'm pretty sure the float has been reproduced.
I know the 01A-9275 fuel sender used 1940/48 on cars has been reproduced.
Old May 9, 2008 | 08:45 AM
GreatNorthWoods
They are original.
I'm more familiar with the aftermarket gauges than the originals so I can't help much. The fact that the gauge needle moves is an indicator that the gauge is probably okay. The problem is likely in the sending unit or the wiring. The 48-52 trucks have rubber insulators under the gas tank that can sometimes interfere with getting a proper ground. You might try temporarily running a ground wire all the way back to the negative side of the battery to be sure you have a proper ground and then see how the gauge reads. I had to run a special ground wire to my sender from a source other than the tank itself...
Old May 9, 2008 | 11:16 AM
NumberDummy
This is what I type for the 1957 thru 1979 crowd, it applies here as well.
The floats are made from two pices of copper soldered together, solder breaks down, gas seeps in, float slowly settles to the bottom of the tank.
dconner
New Member Introductions
Mar 25, 2014 09:04 AM
retiredbanker
Oct 26, 2011 05:40 PM
signatureptw
Vendor Specials, Discounts, Product Announcements & Group Buys
Jul 12, 2011 10:39 AM
ryanksc
Mar 7, 2011 03:05 PM
57Fitzjohn
Apr 17, 2008 03:03 PM
