Hello All,
I recently purchased a LN 9000. The door tag is missing so I would like to find where the vin is stamped in the frame. If anyone knows where to look I would appreciate some help.
The vin from the title is 1FDYW90R3BVJ37341.
Thanks, Bill
Vin may be on the frame rail, top or sometimes inside, sometimes both, just about even with the front axle, sometimes near the alternator if that's hanging over there, sometimes under the cab. It may also be on one or more crossmember.
1FD = Ford Motor Co USA, incomplete vehicle
Y = Class 8, 33,001 - 55,000 lbs GVWR, air brakes
W90 = LNT 900 diesel, tandem axle. (badged and referred to elsewhere as a LN9000)
R = Detroit 6V-92TA or 6V-92TTA 552 CID 6 cylinder diesel engine
Hey 85e150,
Thanks for the info. I’ll keep looking. All my F series trucks have the vin stamped in the place you mentioned but this L has me stumped.
Thanks, Bill
