P0442 Error Code
Old Dec 3, 2022 | 12:33 PM
Junkfood's Avatar
Junkfood
Question P0442 Error Code
2004 Ranger XLT with 4.0L V6 and 5-Speed manual transmission. Recently my "Check Engine" light came on. I took the vehicle to AutoZone to have the EEC-V system read and found the error code P0442, EVAP small leak detected. I first checked to see if the gas cap wan not installed properly, but it appears to have a snug fit. The next thing to check is "Canister Purge Valve", but I'm not sure what I'm looking for. Does anyone have a photo of the "Canister Purge Valve" for the 4.0L V6 engine, or at least the location within the engine compartment?
Thanks!
Old Dec 5, 2022 | 11:21 AM
Creaky's Avatar
Creaky
It should be near (but lower than and forward of) the brake master cylinder. It looks like this:
That electrical connector will be facing aft.
Old Dec 26, 2022 | 02:53 PM
Junkfood's Avatar
Junkfood
Can't find anything that looks like that under my hood.
Old Dec 27, 2022 | 10:00 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Old Dec 27, 2022 | 10:25 AM
Kruse's Avatar
Kruse
If you already haven't, I would suggest that you replace your gas cap. Yes, it's possible that it wasn't on tight and snugging it up might fix your problem, but a replacement Motorcraft (no substitutes, unless it is NLA) gas cap is one of the first things to replace if there is a small emission leak detected. Next, I would try a smoke machine. This will help find your small vacuum leak. A few people have successfully made some homemade units, but any competent indy auto repair shop should have one. Avoid "just throwing major parts" at it.
Old Dec 28, 2022 | 09:44 AM
Creaky's Avatar
Creaky
That's because you said you had a 2004 Ranger. That's what it looks like on a 2004.
If you had said that you have a 2002 Ranger (which I deduce is the case, given your other thread on this forum), I would have posted this picture instead (purge valve is #7):
"Details, details", right?
Good luck in the diagnosis.
Old Dec 29, 2022 | 12:33 AM
Junkfood's Avatar
Junkfood
Sorry! I'm not sure why I typed 2004 instead of 2002. It may have been rather late when I created the original post, and I may have been half asleep. But thank you for the updated information, it is very helpful.
RusPro
4 Cylinder Engines
Feb 11, 2017 10:00 PM
pablocruz69
Aug 13, 2010 12:50 PM
Charger73400
Jan 23, 2006 08:24 PM
steve17bs
Jul 31, 2004 05:15 PM
steverowe
Oct 25, 2003 09:05 PM
