Aerostar Ford Aerostar
moving on
Old Nov 13, 2003 | 10:33 AM
simonstar94's Avatar
simonstar94
moving on
hi again again,
found some of the forum stuff on tranny but fluid is not answer as I probably have too much--how do I get some out .
Old Nov 13, 2003 | 12:25 PM
rickm5's Avatar
rickm5
how much too much do you have?. you could loosen your tranny fluid lines at the radiator (right side as you face the engine) and let some leak out. the upper line is easier to get to. rick
Old Nov 13, 2003 | 12:39 PM
aerocolorado's Avatar
aerocolorado
Small tubing down the dipstick tube and a 60cc syringe will work for small volumes. The same with a drill or hand operated pump will withdraw larger amounts.
Old Nov 13, 2003 | 03:48 PM
agelder's Avatar
agelder
They have hand pumps made for this kind of things for pretty cheap @ the local auto/hardware stores.
