I don’t have the torque setting, but I think a quarter turn after snug is too much for a cone seat.
That might work for a compressible gasket, but you certainly don’t need a quarter turn after snug.
But I’m curious about what the torque is too.
The airhorn of a carburetor or throttle body is generally considered to be the round segment that the air cleaner seals to. However, I think the real definition is just that area surrounding the venturii.
Been so long since I thought about it I guess it’s time for me to actually look it up!
Thank you. I appreciate your response. Some of the plugs were in so deep I had to put a lever on the socket wrench. I could see that if they were old, but they were newer plugs. You are right, I was thinking about the gasket plugs. Almost all cleaned up. I will most likely end up putting on new manifolds and gaskets. After I soak the bolts forever
Does anyone know what I should torque the plugs to. Otherwise I have always just made them snug and given about 1/4 turn.
thanks
steve
The plug torque on all Ford 18MM tapered seat plugs is 15-20 ft. lbs. or 180–240-inch lbs.
The plug torque on the 14MM plugs is 10-15 ft. lbs. or 120–180-inch lbs.
Those numbers can be found in the distributor section of the shop manual.
Do put a drop of motor oil on the threads before you install them.
You mentioned removing the exhaust manifolds in another post. Be very careful those top bolts are famous for breaking off and are a bitch to repair with the engine in the truck.
Autolite has been owned by Bendix for decades. Ford's brand has been Motorcraft. Next time I would go with keeping a Ford product in a Ford. Ford's part number was BSF32C (copper core) for 1968/71 F100/350 with 360/390. As of 1972 when 360/390 got hardened exhaust valve seats Ford changed the plugs to part number BSF42C. Which is one heat range hotter. I don't see anything on g**gle about BSF32C. As per usual g**gle, everything BUT BSF32C. So I would go to Ford or O'Reillys and get part number BSF42C. Stocking number SP420.
With standard points dizzy and stock coil, gap the plugs at .035". Check the points for wear, their gap, and better off yet their dwell with a dwell meter.
Why do all that maintenace with points. Pertronics is a great option to points without the failure rate. I'm 7yrs with Pertronics with only one cap, rotor and plug change (not that they looked bad) but habit told me to. Been running Autolite 45's at .044 with good success on 85 octane in a 410ci FE. My reason is a lower octane needs a hotter spark.
There is no argument that pertronix and their hotter coil isn't better. Except those purists who want the old school experience. Our current gas doesn't have that much different octane. It's just rated differently than when our rigs were new. Exception being areas where gas is sold with methanal/ethanal. Octane makes no difference to plug gap. The main concern would be how hot the coil is sending out a spark. Stock style coil gap should be as listed back then, .035". A hotter coil then .044/.045. IMHO. Plus, I'm sure your 410 isn't running a stock coil. I know if I had a 410 FE it wouldn't be. Sorry if I sound argument of. I'm not. Not my way.
No offence taken. When I got my truck running 7yrs ago after not running for 20yrs, the last thing I wanted to do was keep tinkering with it.
