Ive got a 79 f150 and have been having problems with the front brakes for a good while. they started off having trouble pushing fluid to the back brakes so i swaped all brake line, master cylinder, brake booster and rear wheel cylinders, that seemed to fix that problem, then my front brakes started locking up, ive put on 2 new sets of front calipers and had the same problem of locking up with both sets. Ive cleand the hell out of the proportioning valve and definitely completely bled the lines with both sets of calipers, not sure if i should go about a new proportioning valve or what
Are you positive you have the right master ? drum brakes normally have a residual valve that holds fluid back for a bit. shouldn't cause the calipers to stay on long but without return spring pressure I'm not sure what would happen.
Could be a screwed up proportioning valve I suppose, I've had problems with them but not this.
It could be an adjustment issue between the master and booster. or a defective booster that's not returning properly. I'd pull the hose off it when your brakes are locked and see if it changes anything.
You'll have to pull the master cylinder loose from the booster to do it, but it might pay you to check the actuating rod adjustment between the booster and master cylinder. If the push rod is too long, the brakes will not release once applied.
There are "tools" to measure it or you can make one easily. I'm not sure of the specification, this may be correct for my '77 F-150 ...
... Look down a couple posts to post #5 ...looks like the number is 0.980" min to 0.995" max.
Reason: corrected what might have mislead.
Yep loosen the master from the booster and see if they release.
If not then you know you have to look else where.
We're the rubber hoses replaced?
They can go bad inside but look good on the outside.
Dave ----
... but just a picture of the tool in use:
Bendix single diaphragm,dash-mounted booster
From 1978 Shop service manual APPLIES TO F-100, F-150, F-250, (6200/6800 GVWR), E-100, E-150, F-150 - F-250 (4x4) AND BRONCO
