I couldn't find any posts about this.
I was driving my 2020 F250 yesterday and the check engine light came on. I didn't notice anything different and filled the tank. The FordPass app says "The engine control system has detected an electrical concern with the engine knock sensor."
I am still under warranty, so taking it in next week. Just wondering if anyone else has had this issue, or if anyone knows what this means exactly.
Thanks!
Knock sensor is just what it says, detects spark knock in the cylinders, ecm retards the timing a little if it detects knock, this is what lets the engine operate on varying octane fuels.
Not sure where it is on the 7.3, but will be screwed into the block somewhere.
Thanks!
I had the same thing happen with my 2021 F350 with the 7.3 last week. CEL was on for two days then went off. Same message on the FordPass App. Took it to the dealer since I'm still under warranty, of course they said they found nothing wrong.
I'd like to find where the sensor is myself without spending $226 for the service manual.
My truck has thrown this code 3 times now. The first time it was headed to the dealer for other reasons - they cleared the code and it didn't return after they drove it. A week or so later the code returned but I topped off with premium and it went off on its own after a couple days. I thought perhaps I had a bad tank of gas so I started running mid grade. Fast forward one month and it threw the code again, and again it went off after a couple days. Sooo...it's tough to replicate. I'm out of warranty now but it was documented with them before warranty expired so I'm guessing it would be covered.
If it's an easy repair and the part is cheap I'll probably open fire with the parts cannon rather than have the truck be down & sitting at the dealership for a couple days.
Maybe the sensors are doing what it is supposed to do?
If what info out is true then the 7.3has 10:5 pistons. The 6.8 has 10:8. Is this not high test gas territory?
I know the computer is supposed to retard timing so it can use low octane gas. With that fact. Why not use high test and let the computer advance timing?
The owners manual even has a blurb about running high test when pulling is not a bad idea.
They're not supposed to throw codes - as you said, they're supposed to adjust timing. The code is for a knock sensor failure, not a low octane warning. I started running better gas as insurance against the failed sensor not being able to do it's job.
I don't think it's realistic for Ford to expect what was designed as a fleet truck motor to run high test for day to day operations, and I also don't ever recall seeing any documentation to that end.
My 2004 Silverado 2500 6.0 gas would ping and rough idle on Arco 87.
And my local rural gas station is, I am sure, providing the absolute lowest quality gas they can get away with. I'm 40 minutes from the closest Top Tier pumps so changing up is not practical, not to mention the $.
I have not noticed any changes in the way the engine runs with code thrown or without.
My 2020 7.3 has thrown the code twice. First time at round 10k miles and warranty replaced the sensor. Happened again a year and half later and service told me a rock had chaffed the knock sensor harness they replaced it then wanted to bill me I think it was over $400. I called BS and asked to see pics of the rock and the old harness. They ended up covering it under warranty. What they actually did or replaced i have no idea.
It was designed for best performance with 91 or better.
For best overall vehicle and engine
performance, premium fuel with an octane
rating of 91 or higher is recommended. The
performance gained by using premium fuel
is most noticeable in hot weather as well
as other conditions, for example when
towing a trailer. See Towing a Trailer
(page 365).
(page 365).
I remember before they started putting ethanol in gas and 93 was only $0.20 more per gallon than 87. I filled up with 93 in Texas for $3.55/gal and 87 was $3.09 at the same station. Then I filled up with 93 in Indiana and regular was $3.47/gal and 93 was $4.37/gal. I absolutely hate ethanol gas. My 460 and 445 run way smoother and get better fuel economy on clear gas.
those compression ratios are what we used to say were for high-test only , yet in todays world of auto's ratios' of 10 and up are normal, thanks to the use of knock sensors . how high some are is more in the diesel ranges today mazda with the skyactiv-g runs 14.0 to 1, my wifes little 2024 subaru crosstrek runs 13.5 ,heck mazda even has a gas engine called the skyactiv X with 16.3 to 1
I do not buy that physics has changed. How we deal with physics has changed but I fail to understand how preignition is any different with a knock sensor vs without? Other than adjust timing down and limit performance.
The only reason to get by with high compression and low octane is because the knock sensor retards timing.
