2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Side to side clunking
Old Nov 28, 2022 | 05:12 PM
NB64's Avatar
NB64
My 22 has developed a slight clunking noise when the bed shifts from left to right (side to side). Sounds like something loose but no noise when going over bumps. I recently added a sway bar but completely disconnected that and still same noise. A little web research is showing the it might have something to do with the spring pack. Anyone else having this sound?
Old Dec 3, 2022 | 06:42 AM
NB64's Avatar
NB64
Upon further investigation it’s definitely the leaf springs, it’s the middle and the top spring that have play in them. Since my driver’s seat heating/cooling stopped working I’ll wait to see if anything else happens before bringing to the dealer.
Old Dec 5, 2022 | 01:34 PM
JKBrad's Avatar
JKBrad
Did you have a taller block put in the back? Try to see of the leaf spring bolts are loose. They should be torqued to at least 110 ft lbs.
https://www.suspensionspecialists.co...nformation.pdf
Old Dec 5, 2022 | 02:56 PM
NB64's Avatar
NB64
Thank you but no everything is stock. I did torque the U- bolts a little more. But there is slight movement between the middle and upper springs. That translates to a clunking noise that can be felt in the spring pack on both sides.
Old Dec 7, 2022 | 12:18 PM
NB64's Avatar
NB64
While reading about this issue I found a fix on another forum. The guy had the same issue as me. Ford recommended replacing the entire spring pack. But the Ford tech basically removed the rear components, I.e rear bumper, shocks to verify the cause. Once he isolated it to the springs he loosened the rear shackles and retighten, resolving the issue. On my truck I leaned in over the rear tire and used my back against the fender to lightly rock the truck. I touched the spring pack and could feel the clunking. So today I loosened the rear bolt going through the the spring (both sides) and retighten. The issue is now gone. This was an issued that occurred after some miles were put on.
Tact
Dec 17, 2022 12:53 AM
crisx
May 1, 2014 03:28 PM
gustov12
Apr 23, 2007 10:58 PM
Lucca
Oct 4, 2003 08:34 PM
dockman
Nov 27, 2000 12:44 PM
