I too like Franklin have changed my steering gear and the steering wheel is off a bit. Been this way since 2018 and my alignment is correct . I have pulled other steering wheels Mopar-International used certain type pullers for each. Puller required for our ford trucks ? TR
My 86 is a base level work truck and doesn't have a tilt wheel, maybe that's the difference. I use a harmonic balancer puller to pull my steering wheel, works great.
My only comment on this is when I used a gear puller to remove the wheel on my 86 when I was 17 (1998) I basically ruined the stock wheel trying to get it off it was on so tight.
Our master Ford engineer who left us unexpectedly also said something about the master spline. I have no doubt that Ford might have put a master spline on there, but it doesn't seem to work, you can put the steering wheel anywhere you want.
I changed the steering box on my 89 when the bottom seal blew out. Everything was centered and good, all I did was change the steering box, and after that my steering wheel was off. It drove fine afterward, so all I did was pull the wheel off and set it to the correct position and stuck it back on. No problems so far.
I hate that if he’s left us. I loved that guy. Most knowledgeable human on the planet on Ford trucks. I’ll damn sure miss him !!!
Good to know , found metal ,the 5\16- 24 x 2 inches are are to find ,but flea bay has them.I did find a steering wheel puller in one of my tool boxes .still going to make Karl’s version.I like simple.TR
