Sponsored by: Auxito
PCM control module question.
Old Nov 17, 2022 | 04:40 AM
troy98f150's Avatar
troy98f150
4wd Low
I want to replace my pcm module but when I try to order one they want my specific part number. The one in my truck was previously replaced and it got no part numbers on it. Is there a way to maybe search my vin to find correct part number?????
Old Nov 17, 2022 | 10:41 AM
formerjeepguy's Avatar
formerjeepguy
Why do you "want" to replace the PCM?
I got my PCM from flagship one. They used my VIN to match it up and flashed it with all applicable updates. They were cheap and easy. Keep in mind that you will need to sync a new PCM to the rest of the modules in the truck and you may need to reprogram PATS.
Old Nov 10, 2025 | 01:48 PM
desertdave35's Avatar
desertdave35
Can you explain how to "sync" the modules to the new PCM or where I can find this information using my FORscan?
Kingair90
Aug 1, 2025 08:40 AM
ST42
Oct 2, 2023 01:41 PM
Gump_Runner
Jan 1, 2023 11:43 AM
ehgeeray
Jun 5, 2010 03:17 PM
