HELP PLEASE
Old Nov 19, 2022 | 07:20 PM
ranger140892's Avatar
ranger140892
Grumpy goat
It's a T18 transmission, and a NP205 transfer case. Just what you need for a Ford. I think you're in business. I don't see the driver's side transfer case bracket. It bolts to the transfer case, and to the driver's side frame rail. If you don't have it, that's not a show stopper. It can be easily measured for and fabricated after everything else is installed.
Old Nov 19, 2022 | 08:40 PM
1browski's Avatar
1browski
I dont know how it works on a married set up but in the earlier 70s, the T18 didnt have the bosses to mount your transfer case shifter. This is a 73 T18 going in my 72 f250.
I had to make a bracket to carry the shifter.
Old Nov 20, 2022 | 07:25 AM
ranger140892
Grumpy goat
On the married setup, the transfer case shifter mounts on the adapter, not the transmission or transfer case.
Old Nov 20, 2022 | 07:56 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Married 73-76
Married more detail of the xfer case mount.
Divorced xfer case.
Old Nov 20, 2022 | 08:41 AM
ranger140892
Grumpy goat
Just a thought on this...As much as I prefer manual transmissions in trucks and Jeeps, I'd probably stick with the C6 in this case. If your truck has all the crossmember, bracketry, and hardware for the C6, it'd be much easier and less expensive. Even if you have to replace the C6.
