Sponsored by: Real Truck
How does TPMS work in 11-16?
Old Nov 16, 2022 | 02:28 PM
HokieHiVPI's Avatar
HokieHiVPI
I have a '15 250 Platinum and I was surprised there wasn't a menu for reading the tire pressures. I thought I'd drop 30 pounds of air out to see if I could activate it in the driveway. No messages. Are they the kind that require inertia to provide a reading? I haven't tried driving around the block yet but was just curious in between meetings here. Thanks in advance.
Old Nov 16, 2022 | 04:54 PM
HokieHiVPI's Avatar
HokieHiVPI
Alright, follow up question. I got the low pressure notification on the dash but I've filled it back up to 60psi and it's still on... do you have to perform the reset procedure every time there's a low pressure situation?
Old Nov 16, 2022 | 05:31 PM
cj45lc's Avatar
cj45lc
No you shouldn't have to, but you might have to put more than 60 psi in the tire to get the light out & then adjust your psi.
Old Nov 16, 2022 | 05:40 PM
HokieHiVPI's Avatar
HokieHiVPI
Ok cool, thanks, I'll give that a chance.
Old Nov 17, 2022 | 09:13 AM
geodane's Avatar
geodane
The manual states that when proper pressure is restored the vehicle is to be driven above 20 MPH for 2 minutes to clear the light.
Old Nov 17, 2022 | 02:21 PM
HokieHiVPI's Avatar
HokieHiVPI
Thanks for that! Funny enough this morning it was reset magically and it never moved more than 50 yards.
Old Nov 17, 2022 | 09:02 PM
WWR's Avatar
WWR
Answer: poorly
Old Nov 18, 2022 | 08:43 AM
saratoga2011's Avatar
saratoga2011
You have to drive like others have mentioned to activate the TPMS sensors unless you have the shop tool to hold next to them and activate them while the truck is stationary.
But yes, it sucks. There's no tire pressure monitor in the dash, just the light which is super unhelpful.
Old Nov 18, 2022 | 11:01 AM
acdii's Avatar
acdii
Install a Kenwood head unit with the OBDII connector and you can read the tire pressures on the gauge screen. Might be able to do it with scan gauge or other tools through ODBII. The TPMS sensors do have a sleep mode to conserve the batteries, and usually require some rotations to activate.
jdcrowe75
2004 - 2008 F150
Apr 13, 2015 06:47 PM
Tailgate77478
Dec 22, 2014 12:34 PM
Doc
1997 - 2003 F150
Apr 10, 2013 08:29 AM
Aarkie
Jun 25, 2006 02:35 PM
Dairyf350crew
Sep 14, 2004 01:36 PM
