Sponsored by: Real Truck
Memory Steer With New Ball Joints
Old Nov 11, 2022 | 09:02 PM
DClawson73's Avatar
DClawson73
4th Gear
Good Evening,
I installed a new set of Motorcraft ball joints on the drivers side of my 2006 F350 4wd about 500 miles ago. Since then I have been having a big problem with memory steer. I've tried taking it all back apart and re-doing the ball joint torque sequence and greasing the joints, but they are still unbelievably stiff once torqued down. It still turns freely with the upper joint fully torqued and the lower around 80, but past that it is almost too stiff to turn the knuckle by hand. Any ideas as to what could cause this? Thanks in advance.
Update: I threw out the brand new Motorcraft ball joints, and put Moog on the truck, and the problem is fixed. Thanks for the input.
Old Nov 12, 2022 | 02:16 PM
reptar0077's Avatar
reptar0077
If its the same as my 03, the top ball joint has a split bushing with a chamfer on it.
So if you tighten it down to hard it will literally bind the hub in place pretty hard.
You have to re-tighten them in the proper sequence again and it should be gone.
MAKE SURE they feel relatively the same in resistance being pushed back and forth by hand.
EDIT-Wrong ball joint
Old Nov 12, 2022 | 08:58 PM
DClawson73's Avatar
DClawson73
4th Gear
I tried it by the book, and using the method in your video, and am still having the problem. An additional thing I noticed is that once the lower ball joint is fully tightened, the nut for the upper is very loose. Any other ideas? I guess I could press the new ford joints out and try moog?
Old Nov 13, 2022 | 01:54 PM
reptar0077's Avatar
reptar0077
You want to do the upper one last? The bottom one takes all the trucks weight when its on the tires.
Make sure that they have the small gap on the top like I said in the video. Thats the binding part.
Old Nov 14, 2022 | 10:15 AM
DClawson73's Avatar
DClawson73
4th Gear
Sorry if I came off as rude, the ford procedure said to tighten the lower to 35 ft-lbs, then the top to 69 ft-lbs, and then the lower to 150. Once the lower is at 150, the nut for the upper ball joint it extremely loose. Maybe the joints weren't pressed in right? I cleaned up the assembly, and made sure the ball joint was fully seated, but the upper does stick out the bottom of the hole slightly further than the old moog one did.
Old Nov 14, 2022 | 01:11 PM
Djosbun's Avatar
Djosbun
You either have the incorrect ball joint (box is correct but part is not) or you have installed them incorrectly or are over-tightened.
— Dave
Deadsquiggles
Jun 6, 2021 01:27 PM
jhobbs26
6.4L Power Stroke Diesel
Jul 5, 2018 02:01 PM
WHEELZCRAZY57
Jan 1, 2015 05:21 PM
LSO1123
Sep 28, 2011 10:03 AM
websthes
Apr 30, 2008 09:41 PM
