460 exhaust
I have to confirm that my truck has car manifolds. I see exactly what you're talking about kjkozak2. Whoever did the engine swap used a torch to remove a section of the frame to get the passenger side manifold to clear. Without being notched, the manifold points directly at the frame rail. I guess it was easier to notch the frame than to find a manifold. That's probably why there's a 3" suspension lift on the truck too, so they could use the car front sump oil pan.
I have said more times than I can recall exactly what mil1on says. Passenger Car Exhausts DO NOT WORK.
It req's a R/H Truck Exhaust Manifold, or settling for headers to put a 460 in 65-79 F Series. I'm probably one of few who actually prefer cast Iron OEM Manifolds for the adequate back pressure they do offer.
I'll spare you details, but suffice it to say I/m quicker at a faster speed with OEM cast iron exhahusts on my virtually box stock 385 than I was with headers I took off & sold. I also get better mpg w/ CI Exhaust. In reality my truck is a cruiser, not a racer.
One thing I can say for sure is stay with OEM style steel "shim" type gaskets with heat shield on them. According to FoMoCo, CI Exhaust manifolds rely on coolant flow in cyl heads as "sink" for excess heat build up. Use of composition, or combo composition/ steel gaskets MAY be cause of cracking in CI Exhaust Manifolds.
Fiber composition acts as an insulator, slowing or stopping heat transfer required to protect CI Exhaust mainfolds from an excess internal heat build up cracking them.
I read that in TSB a long, long, time ago, far, far, away when it was still popular to put 460s in Vans, Ambulances, Mini & Medium Motor homes and other app's where heat is an issue.
I've used same set of F Series manifolds on a few engines over the last 15, 18 years. They have not warped or cracked yet. I've yet to plane or reface them, They have over 1,000,000 miles on them at least.
As I exit, Dutherlerfordparts, when/ after you get your system straightened out, weld a repair plate over the missing section. The kick or up step at bottom of fire wall is the wrong place to cut a flange, top or bottom, off a frame rail ! It's a MAX STRESS area
as far as dynamic "loading" goes.
On running Duals. The OEM system used a "Y" or cross over to get around Auxiliary Fuel tank location. If you lack an Aux Fuel Tank fabricate L/H system from outlet @ manifold or header, all the way to the rear, or side exit, whatever. . . .
If you have Aux Tank, do what FoMoCo did, go around it.
Now I've seen 2 types of "Y" or crossover pipes. & 3 types of OEM Systems. One's single all the way after 2 into 1 @ "Y", then another is 1 in & 2 out of muffler all the way back, and 3rd is dual
"Y" with 2 into muffler and 2 out of muffler all the way back. What I dislike is how tailpipes are close together & side by side 'til they exit.
FBp.
