Gravity bleed
Old Nov 5, 2022 | 06:30 PM
John11.25's Avatar
John11.25
Gravity bleed
1996 F-250, 4WD, Extended cab. New NAPA calipers, front brake hoses, and a pair of Bilstein 4600 shocks while I had the wheels off. I did a gravity bleed on the two front calipers but not sure if it was enough. The truck stops, but the pedal doesn’t feel all that great.
I usually drive another late model Ford truck daily, so every time I use the OBS the brakes feel terrible. Can’t really tell if they are better now or before.
I put the new calipers on because I had one sticking awhile back.
How do you know when you have bled the lines enough?
Old Nov 5, 2022 | 06:32 PM
00t444e's Avatar
00t444e
Bleed until no more air comes out.
Old Nov 5, 2022 | 09:11 PM
knottyrope's Avatar
knottyrope
With truck off and vac released. Pedal should barely move once air is out.
IF mushy, there is air.
Did you do rears first and RABS?
Old Nov 6, 2022 | 06:58 AM
FinnishStroker's Avatar
FinnishStroker
I do nothing else than traditional brake bleeding.
No vacuum or gravity bleed for me.
Old Nov 6, 2022 | 07:10 AM
John11.25's Avatar
John11.25
Thanks for the reply. I just bled the front, since that was all that I opened up. Should the whole system be bled?
Old Nov 6, 2022 | 07:38 AM
knottyrope's Avatar
knottyrope
If it's always been bad feeling on the pedal. Bleed it all.
if caliper was sticking. Double check booster to MC clearance for .02 in clearance. If too close, vibrations can make it contact and engage brakes. I chased this for weeks and only take a few minutes to check.
Old Nov 6, 2022 | 02:38 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
I gravity bleed to get the main **** out while I do something else, like change the oil or make a sandwich. Once the fluid is clear, I will use a length of hose into say an old Grey Poupon jar/mason jar/etc and flush the rest myself. No air sucks back in, not to worry. You would be surprised how much more crapola comes out of the calipers with flushing via the pedal. I have done a few vehicles that took over one gallon to flush clear.
Also, go backwards a few times in a parking lot (SAFELY) and dynamite the brakes. This will help set the rear drum auto adjusters. I try to about once per month of daily driving the dually.
Are your rotors new or at least turned? That could pose an issue with the pads attempting to bed.
Old Nov 6, 2022 | 04:22 PM
John11.25's Avatar
John11.25
Thanks for the advice, looks like I’ve got some more work to do, as the pedal is still soft. I did nothing to the rotors as they seemed smooth to the feel by hand. I considered new rotors, but they seemed good and still in spec.
I guess the pads will eventually conform to the rotors??
Old Nov 6, 2022 | 04:48 PM
John11.25's Avatar
John11.25
I’ve driven less than 5 miles with it, just to test the stopping ability. I could get some of those Summit Racing extreme performance rotors. They have a decent price on them.
Old Nov 7, 2022 | 11:35 AM
knottyrope's Avatar
knottyrope
never bought a performance rotor or pads, stock has always done me well
Old Nov 7, 2022 | 12:11 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I gravity bleed all of my junk. I've got spare time and I'm by myself.
One trick that has helped me immensely over the years is to tap each caliper on the back (piston) side with a small hammer while the bleeder is open. The castings are ROUGH on the inside and air bubbles will often cling to the inside walls of the caliper bores. Tapping the caliper will cause the bubbles to "break off" of the casting flash.
Old Nov 7, 2022 | 01:07 PM
knottyrope's Avatar
knottyrope
caliper pistons hold enough fluid that i put back in my old pads, pumped pedal till hard and compressed the caliper fast with big c clamp and put in new pads
that did better than bleeding it for an hour
Old Nov 7, 2022 | 03:21 PM
John11.25's Avatar
John11.25
I’m still a novice when it comes to most of the stuff on this truck, so the advice and help by everyone is much appreciated.
Joshua Ade Richards
Large Truck
May 9, 2022 04:49 PM
Farmerrye
Nov 28, 2020 01:08 AM
thefew
Mar 1, 2020 06:31 AM
Sac79
113
Sep 11, 2019 03:24 PM
saratoga2011
May 13, 2019 03:00 PM
