Spark Plug Inquiry
Old Nov 5, 2022 | 03:29 PM
LiquidCowboy's Avatar
LiquidCowboy
Spark Plug Inquiry
Any idea on the next colder plug than Autolite #45? having a hella time trying to locate reliable info. Tried using search function too.
in a 72 429, normally im messing with 335 series
Old Nov 6, 2022 | 10:21 AM
White Lightnin''s Avatar
White Lightnin'
45 is the hottest plug
Old Nov 6, 2022 | 11:56 AM
LiquidCowboy
yeah i get its hot, i have a Petronix on it and want to go to a colder plug
Old Nov 7, 2022 | 05:54 AM
DaveMcLain's Avatar
DaveMcLain
With Autolite plugs the last number is the heat range. A 5 is a pretty typical heat range for a street engine so you could go to a plug with a 4, a 3 or a 2 to get something colder but all numbers are not generally available. The 45 is a Power tip style of plug so you might have to go to a conventional plug and or non resistor to get the heat range that you want. I think that they make a 32 and a 33 which is colder with a standard tip. You might have to order those plugs with an AR prefiAutolite Racing).
Most of the time a 4 or 5 is about right for a street engine to allow the plug to stay clean yet not cause preignition problems.
Old Nov 9, 2022 | 09:44 AM
White Lightnin'
My bad, not sure how I got that mixed up in my head. With my screwed up ankle I am on too many pain killers I guess. A 44 would be next step colder.
Old Nov 9, 2022 | 10:09 AM
DaveMcLain's Avatar
DaveMcLain
In Autolite plugs you can even get a 6 heat range in the 18mm power tip resistor plug. curiously my heat range chart doesn't show the 44 plug. In the Power Tip style of plug they show a 46, a 45 and a 5125 which is a long shell design in a 5 heat range. In a non resistor there's a 36, 35, 33 and a 32 listed. Standard tip resistor there's a 124, non resistor standard tip shows a 113.
I hope that helps.
Old Nov 12, 2022 | 11:12 AM
LiquidCowboy
I hope that helps.
Hey Thanks! thats exactly what i was looking for. 124s on order now, too bad work DOESNT have an autolite book (O'Reilly)
Now to track down another gremlin (its always something isnt it?)
Hotpocket
Jul 20, 2020 08:31 AM
beckman
1997 - 2003 F150
Jun 11, 2013 07:20 PM
zarillus
May 22, 2008 08:05 PM
shwagy357
General Automotive Discussion
Feb 24, 2005 11:45 PM
