Brake Fluid Reads Low (Brake Light On)
Old 11-04-2022, 12:23 PM
balls2thewall's Avatar
balls2thewall
balls2thewall is offline
4wd Low
I have read the other threads pertaining to the brake indicator light staying on. I connected forscan and in the IC module the brake fluid was reading low. I removed the connector from the brake fluid level sensor and jumped the two wires and that indeed turned the light off, for a few minutes.....
I connected forscan again after the light came back on and the brake fluid level was reading low with the wires jumped and "open" with the jump removed. This didn't make sense to me but I replaced the brake fluid level sensor anyway and it's still reading low after plugging the new one in. During the installation of the new sensor, the light turned off with the connector unplugged (and nothing jumped). This did not happen the last time I unplugged the sensor.
This seems so random. Any ideas? Does the IC module actual show the sensor reading, or would the common cluster soldering issue cause a low fluid level reading in forscan?
Old 11-17-2022, 03:46 AM
Dr.BunnyFooFoo's Avatar
Dr.BunnyFooFoo
Dr.BunnyFooFoo is offline
4wd Low
Did you do work on brakes recently ?
Bad connector or wire maybe?
Old 11-17-2022, 09:54 AM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,298 Likes on 1,098 Posts
Parking brake is released?
Old 11-17-2022, 01:49 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
It has a bad solder joint on the circuit board. Not hard to fix
icentropy
05-21-2016 12:25 AM
4mrBowTie
08-25-2010 07:42 PM
jpcnorthwood
06-28-2009 07:59 PM
snowman79
Escape & Escape Hybrid
02-18-2009 07:58 PM
mleflore
12-17-2003 02:46 PM
Quick Reply: Brake Fluid Reads Low (Brake Light On)
