Power steering conversion
Old Nov 2, 2022 | 07:56 PM
1965_Ford's Avatar
1965_Ford
Did you do a power steering conversion on a 65 352 motor or similar? I have been reading and it seems like a pain. Is it worth it? I'd like my kids to be able to drive without all the muscle. I am open to suggestions.
If someone knows of a shop in Los Angeles area I would like to talk to them.
Old Nov 4, 2022 | 02:00 PM
85e150's Avatar
85e150
Is this for your '65 F100?
You'll get more info in the truck forum and I'll move you there if you like.
IMO, short version, keep it as it is, and the kids will develop arm muscles like all of us who drove older vehicles. Added on linkage assist power steering leaves a lot to be desired, again, imo. There may be other solutions but we need to go to the truck forum.....
Old Nov 4, 2022 | 09:26 PM
1965_Ford's Avatar
1965_Ford
You can move the thread. Just at this point theres no way the kids are driving that thing.
I have a lot of work to do, but its coming along.
Old Nov 13, 2022 | 01:08 AM
HydroDog's Avatar
HydroDog
I did the conversation on my 65 F100 but I have the 300 six.
It’s fairly straightforward but you will either have to shorten your column of find a shorter one.
You well also need to find pump brackets for you FE and if your crankshaft dampener doesn’t have a 2 groove pulley then you will need that also.
I found a 77’ in a wreaking yard and stripped the whole steering and disc brakes off of it. Best thing I did.
Old Nov 13, 2022 | 07:43 AM
retired ironworker's Avatar
retired ironworker
There is a whole tutorial on Fordification.com, lays it all out.
Old Nov 17, 2022 | 10:52 AM
Cbuckner6's Avatar
Cbuckner6
1st Gear
I just converted my 1966 f100, a guy at the Pomona swap meet sells parts for the conversion. I got the ps steering box, pump and brackets, the pitman arm and the hoses for $700. The only thing you have to get is a shortened steering column rod or have your rod shortened.
Old Nov 18, 2022 | 06:52 PM
Christmas's Avatar
Christmas
Don't forget the motor mount stand for a latter model PS truck. Your frame is already drilled for it.
Old Nov 21, 2022 | 10:35 PM
PROSTOCK's Avatar
PROSTOCK
65' 352 v8. I got the PS pump, bracket, pulleys, and some hose off a mid 70's sedan with 390. It was cheap but that was 30 years ago. Prolly hard to find now. Gear came off an '81 but they are all the same in that time period. MUST be a V8 gear. Well worth the effort, but $700, that hurts. V8 PS gears are hard to find for an FE
440 sixpack
Oct 17, 2018 11:35 PM
62/Unibody
Aug 13, 2004 08:25 PM
danimal
Oct 20, 2003 01:20 PM
63unibody
Feb 8, 2001 07:03 AM
Mark Smyth
Mar 7, 2000 05:48 PM
