79 8' bed rebuild idea?
Old Nov 12, 2003 | 04:23 PM
dynamic's Avatar
dynamic
I was sitting on my porch today and I had an idea! I have a 80's pick up bed that is kinda tired on the outside skin. but the guts are great.I was thinking about taking the inner pieces of the bed and grafting the outer skin from the 79 bed on the out side.
any one ever do this... will the panels fit? Im having trouble getting any kinda good 73-79 bed and thought this might be a great alternative. That is if it would work.
Old Nov 12, 2003 | 10:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
Well they might not fit 100% but if you have the type of sheet metal skills that would be required to contemplate a job like this I don't see why it couldn't be done.
Old Nov 13, 2003 | 12:02 AM
Scoarch's Avatar
Scoarch
for 300 plus taxes (can dollers) you can get a brand new jobber
bed.
comes in 2 pieces, a left and right half.
Old Nov 13, 2003 | 11:22 AM
hillbillyk's Avatar
hillbillyk
I knew a guy who did this, he said the insides are the same, just the skins are different.
Old Nov 13, 2003 | 11:38 AM
73Custom's Avatar
73Custom
I was 'told' that the inside and structure are the same from '73 - '96, just the bed skins are different. But I'm not sure.
Marty
Old Nov 13, 2003 | 02:10 PM
460f250's Avatar
460f250
Scoarch, where did you see these bed parts? I thought about just using checker plate, it would be tough enough.
Old Nov 13, 2003 | 03:44 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Yep, it can be done. I believe you need to change the back pillars too.. If i'm remebering correctly the tailgate didn't want to close quite right
Old Nov 13, 2003 | 06:31 PM
Scoarch's Avatar
Scoarch
469F250
this is the place for those bed parts
N.B.R. Distributors LTD
4506b 29th Street
Vernon B.C. v1t 5c1
ph (250) 542-1115
the parts are in the -Cross Canada Autobody Supply LTD- catalogue.
part # 574-46
Old Nov 13, 2003 | 11:54 PM
460f250's Avatar
460f250
Thanks Scoarch
Old May 17, 2004 | 04:56 PM
dynamic's Avatar
dynamic
wooooopeeeeeee
Excuse my enthusiasm, but the skins fit like a glove. I even reused the existing rear posts. Just did a little creative welding. And everything lines up. Tailgate lines up just fine.
Just thought I would let you all know how I made out.
Old May 17, 2004 | 06:05 PM
Scoarch's Avatar
Scoarch
That is sweet. i wonder if short box is the same?
was the swap very hard?
Old May 18, 2004 | 04:45 PM
dynamic's Avatar
dynamic
It wasnt very difficult . but it requires some special tools and a bit of patience. your obviously gonna need a mig welder. but your also gonna need a spot weld cutter.(make sure you have plenty of extra blades. Trust me!!!) Its about 100 spot welds per bedside that you have to cut off. I didnt bother trying to save the inner wheel wells. I just purchased new ones. So those were left to Mr. Sawsall. So cut all the spot welds on both beds. Swap the skins. Line everything up. And weld away. I ended up leaving the rear posts from the 86 bed in tact, and wraped the 79 rear post partially around the 86 post. So its tough to tell unless you really look at it. If you really wanted to go all out you could buy the actual rear posts and swap them out as well. They are cheap money, But I wanted to see if I could do this with as little change as possible.
