transmission leakage
Old Nov 2, 2022 | 12:06 PM
smokeytok's Avatar
smokeytok
1st Gear
I have a 1987 F150, C6 transmission used with a snowplow. I have transmission fluid blowing out the vent pipe of the transfer case. Can transmission fluid come out of the transfer case into the transmission? Any help would be appreciated. Thanks.
Old Nov 2, 2022 | 02:33 PM
andy011's Avatar
andy011
Do you mean can transmission fluid come out of the transmission into the transfer case?
If so, I think the answer is yes. Check your transmission fluid level. Is it very much low? If it is, and there is no other obvious leak, you know where it has to be going.
Old Nov 2, 2022 | 05:15 PM
spurredon's Avatar
spurredon
Isn't there a center seal or something on the torque convertor! At any rate it doesn't sound like happiness.
Old Nov 3, 2022 | 07:00 AM
My4Fordtrucks's Avatar
My4Fordtrucks
How did the torque converter get installed on the rear of the transmission?
I suppose it could if the seal on the transmission output shaft failed? There is only a large paper gasket between the two housings. Are you sure it isn’t coming out of the trans vent and running back to the transfer case?
Old Nov 3, 2022 | 09:50 AM
bulletpruf's Avatar
bulletpruf
This^^^.
Had this happen to me on an old Shivverlay...
Hunter3006
Mar 20, 2022 01:00 PM
Pastor Scott K
Aug 17, 2020 08:32 PM
2002Ex
Jun 27, 2020 09:55 PM
stepside64
Offroad & 4x4
Mar 25, 2004 08:57 PM
bigf150
Feb 2, 2002 09:18 PM
