T style raido
Old Dec 15, 2022 | 01:37 PM
  #31
eminence1963's Avatar
eminence1963
Originally Posted by Spooledsrt
Thanks for the reply. I was wondering if a toslink cable could be used. I plan on running that to a DSP then from the DSP i can run rca's to the 2 amplifiers i have.
No toslink cable on this unit. But your rca and DSP unit will work fine. The benefit of this unit it has its own built in DSP. so no outboard DSP is required. To be honest and just a theory of mine I bet the rca's are for sub only. I cant confirm this as I have not installed anything but the head unit itself at this time. On the dsp screen on the unit itself the is a control for sub out and SPDIF out. I'll get you a screen shot to show you later.
Old Dec 15, 2022 | 01:51 PM
  #32
eminence1963
DSP screen shot
Old Dec 15, 2022 | 01:55 PM
  #33
eminence1963
Originally Posted by Johnny F2 fiddy
I might have liked one of those in my 2015 Lariat. I am not happy with the way they put the top buttons on top of the bezel, as it looks like there would have been just enough room at the top front edge for them.
I agree with that. Maybe in the future they will address that. But I am ok with were they are at. You can still see they in the sitting position.
Old Dec 15, 2022 | 01:57 PM
  #34
eminence1963
More screen shots
Old Dec 15, 2022 | 04:27 PM
  #35
Spooledsrt's Avatar
Spooledsrt
Originally Posted by eminence1963
This is the sub and amp I will be installing once the snow is gone. Also got the MTI bracket kit to move the back seat forward so sub and amp are behind seat. I believe that the factory storage under seat tray will have to be removed to move seat forward. I wont know for sure until I get on with the install though. But my preliminary inspection tells me it has to be remove, or at least cut to make it work. If it has to be cut I will just take it out and store it.
let me know what you come up with on the underneath tray with the seat forward kit. I have one Im waiting to install when i upgrade to the double MTI box for the jl 13tw5 subs. I have the single one back there now and fits great. I was hoping to be able to make the underseat tray work as long as it doesn't take alot of cutting.
I was really wishing this headunit had F,R and sub rca outs. Im ready for a change with the factory unit and Pac module.
Old Dec 15, 2022 | 04:32 PM
  #36
Spooledsrt's Avatar
Spooledsrt
DSP screen shot
The reason I want to run a DSP is to be able to run full active on the 3 way components I have which is also from MTI.
Old Dec 15, 2022 | 05:28 PM
  #37
eminence1963
I understand. Nice setup BTW
Old Dec 15, 2022 | 05:34 PM
  #38
eminence1963
Will do, but most likely wont be till the spring due to crazy weather were having here!
Old Feb 25, 2023 | 05:07 PM
  #39
eminence1963
So the weather broke here and got the amp sub and seat relocation kit installed. For such a little sub this fills the cabin with all the bass you will need and then some. Now on with a slight issue that according to Yulu there working on the fix and a update is forth coming. The RCA's are as of now a fixed output, also the radio and sirius fm do not work with the sub. The rca's only work with android side of unit. So if you want your sub to work with music you have to have a app for that. Also the amp you install will need a inline volume control, you cannot control the sub output with the volume **** on the radio. Even the spdif is not controlled buy the volume **** on the radio. Like i mention earlier their working on the fix for that too. I have not finished making the wiring all neat and hidden. Also the grill got dented from the protrusion of the bracket on the seat itself. I had to cut away some of the material to prevent that from happening. Now the seat can be used as normal without denting the grill. Just need to clean that up as well as some other minor tweaks, when it warms up. As far as the head unit it has been rock solid no quirks even in sub freezing weather.
Here is a email they sent me
Thanks for contacting us.
1.Unlike the ordinary aftermarket screens, E10 retains the original audio host in order not to lose the sound quality and FM/AM signal. Meanwhile, it is also to keep SiriusXM and some OEM functions While the hardware of FM/AM/SiriusXM is built in the original audio host, the sound signal is directly output from the amplifier in the original audio host to the vehicle speaker, and cannot enter SPDIF and RCA output ports through E10 in the opposite direction.
2.The E10 only uses UI and instructions to control the FM/AM/SiriusXM hardware, and can only output USB audio and the sound of Andriod APPs to the external amplifier.
We'll add a volume control module on RCA ,And transferred to SPDIF through RCA. After that, we are able to control the volume of Android apps when you hook up the aftermarkt amplifier.but also can't control the AM/FM Sirius XM volume.
3.We have been working on this control panel for several months,Now that the hardware part has been completed,
our engineers will start the software part at the end of the month.any updates I will let you know.
Old Oct 12, 2024 | 01:09 PM
  #40
ClassicMuscle's Avatar
ClassicMuscle
4wd High
Has this issue been resolved? I need to upgrade from the 4.3 screen on my 2017 F250 to something larger and I'd also like to add some more cameras since mine doesn't have 360. I wondering since it's 2024 almost 2025 now is there a better unit out now or a newer gen that address the issues this one has like the buttons on top and the loss of quality of the mic? How is yours still holding up now and would you buy it again?
Old Oct 12, 2024 | 02:30 PM
  #41
eminence1963
No I would not buy again. There are better units out there from when I purchased mine back in 2020. I hate that the screen washes out from sunlight. Not bright enough in the daytime sun, Also the DSP is just a fancy EQ with a ton of buttons that 75% of them are useless to tune the system. Look elsewhere and good luck on your journey in car audio
Old Oct 12, 2024 | 07:15 PM
  #42
ClassicMuscle
4wd High
Thanks for the reply and your honest opinion you might have saved me from buying one . You say there are better t style units out now which ones do you recommend I look into. i haven't had the truck but for a couple weeks and got $2000 put back to invest into a system. I'm hoping that I can find a system that would allow me to add a front, cargo, and trailer camera or even better a 360 setup since its about impossible to add a factory 360 setup..
Old Oct 12, 2024 | 07:32 PM
  #43
eminence1963
Too be honest I am not sure what to tell you on another brand as I am stuck pretty much with the one I have in the truck right now. Cant afford another one so this yulu stays for now. I hope you can find what your looking for. Best of luck is all I got.
bigrayq
Apr 12, 2011 08:31 AM
2000Expy
17
Feb 6, 2008 06:13 AM
Beerstalker
26
Mar 28, 2007 09:20 PM
vatreefarmer
Mar 15, 2007 09:51 AM
JohnnyBoy
2004 - 2008 F150
Feb 16, 2005 10:53 AM
