2.5 MPG
Old Nov 1, 2022 | 12:37 PM
WhatTheDevil's Avatar
WhatTheDevil
2.5 MPG
1982 E350 (assumed) cab and chassis now camper. Low power, no smoke. So many things on the fix it list, just wondering what to check first on the engine part of it.
Here's the subject:
Old Nov 1, 2022 | 01:46 PM
econo93's Avatar
econo93
I guess some here on the forum might spend 11.5 minutes to find out what your subject/question might be.
Old Nov 1, 2022 | 05:55 PM
WhatTheDevil
So very helpful
Old Nov 2, 2022 | 04:29 AM
JWA's Avatar
JWA
Originally Posted by WhatTheDevil
So very helpful
If you're seeking answers to specific questions by all means post them here--IF you believe anyone has time or interest watching a lengthy video looking to deduce a question and provide an answer you're somewhat mistaken, obviously.
We're here to help, NOT read your mind!
Old Nov 2, 2022 | 06:31 AM
wwwheaty's Avatar
wwwheaty
Great video of site seeing.
I would check for restricted exhaust flow ( cat or muffins) particularly plugged
Old Nov 2, 2022 | 07:17 AM
manicmechanic007's Avatar
manicmechanic007
How smart and in tune with cars are you What The Devil?
2.5 mpg tells me your power valve is leaking (rebuild the carburetor)
You know how EGR works and how to check the rate of ignition timing advance?
You can check an ignition advance amd have a vacuum gauge / pump?
Do you have a timing light? If you can say yes to a few of those questions you have a good start
What to check first? IMO the ignition timing. 2nd , have a smog test done and get a printout of the CO and HC numbers
That old van engine is most likely tired and is not going to run like a creampuff. Do the best you can with what you have
Good luck
Old Nov 2, 2022 | 09:39 AM
WhatTheDevil
It is spewing exhaust out the cracks near the engine so.... maybe!
Old Nov 3, 2022 | 08:31 AM
manicmechanic007
Not sure what you mean spews exhaust out the cracks, but that is bad
The exhaust manifolds are cracked? Gaskets leaking?
Try to get that fixed too
If the O2 sensor sees too much oxygen it has the processor send more fuel to compensate
Old Nov 3, 2022 | 01:25 PM
Hank85713's Avatar
Hank85713
Sounds as if your exhaust system has gone bad. You probably need to upgrade it and should probably start with headers and free flow mufflers (I use Gibson they are free flow and not loud). The engine should not be pollution issue plagued, as in 81-82 should only have had an egr valve, smog pump system. Think about getting rid of the carb and install an throttle body injection system (on youtube one mechanic installed one and was happy (It was his own vehicle, it was a holley unit). This is if you really want to fix issues but will incur some $$ being spent but if this is your desire it is still less than upgrade to new/newer unit. its you call
Old Nov 4, 2022 | 10:26 AM
WhatTheDevil
Check the muffins and O2 sensors or throw a $3,000 EFI system at it. Got it. I'll be starting with the muffins....
If anyone is curious, I am filming what I do to it, my 94 F350, a TJ, and a 1927 Ford on youtube. It'll be awhile before I cut the exhaust off and take a look but active on other things here through the winter. Here's a video I shot of the engine, someone asked what we were talking about and I couldnt remember if it was a 351W or 400m - first time I ever removed that doghouse!
Old Nov 9, 2022 | 03:29 PM
WhatTheDevil
Looking up mufflers on my zero dollar budget here. UGH. I'm not sure what to put on my xmas list. I definitely want free-flowing. I definitely do not want highway drone or raspy revs. Any suggestions? 2.5" 3"? It's already dual and no cats as you saw in the engine video.
Oh and - is there an audience for videos like these? I'm "this close" to meeting the minimums for youtube to start paying me. I would of course re-invest that money into projects like this - an EFI "Carb" conversion is on the wish list... Just need a big enough following to generate the view$.
So I am wondering - if I film it, will they come? Same question with the diesel dually - are these vehicles of interest to people or just old junk now?
Old Nov 10, 2022 | 08:28 AM
Mike1's Avatar
Mike1
If the stickers are still under the hood, it should tell you it's either a 5.8L 351 or a 6.6L 400. So you either have a 351C a 351W a 351M or a 400 For did not make a 400M
As for your changing to FI, Just my opinion, but leave it carbed, you'll be happier.
Your other statement, you want free flowing mufflers but you want them quiet. Well good luck with that.
I myself have never seen a free flowing quiet muffler, but if you want less restrictive but still have some rumble, Thrush or Walker are good alternatives and if you rework the exhaust and move the mufflers further back, you'll get less noise inside your cab area.
Old Nov 10, 2022 | 08:39 AM
WhatTheDevil
Got a set on my 350 chevy, sounds perfect, just don't know what brand they are! No drone, all baritone growl. If you watch the videos I made you'll see what engine it is.
Old Nov 10, 2022 | 11:01 AM
Hank85713's Avatar
Hank85713
I used gIBSON MUFFLERS ON MY 89 F250
Old Dec 19, 2022 | 07:19 PM
WhatTheDevil
Not sure what these are - it got too cold for me to want to lay on the ground under it - I guess it'll be a mystery until spring!
dieseldogtom
16
Nov 3, 2022 09:12 PM
huckster
Modular V8 (4.6L, 5.4L)
May 8, 2015 09:31 PM
BigSilly86
6.4L Power Stroke Diesel
Jan 4, 2012 11:58 AM
cornking
15
Sep 30, 2010 12:31 PM
dynamis5
2004 - 2008 F150
Apr 22, 2007 05:08 PM
