82 Ford e350,no brake lights and rear passenger signal is out. Running lights signal working both front and only drivers rear.
No horn and heater fan works some times if I play with the fuse, no 4 way emergency flashers.
Anyone have the wiring diagram for an 82 e350 with a 5.8 351
That's for vacuum line diagram and for a 1984.
I'm looking for wiring diagrams for a 1982 Ford e350.
I don't play with paypal or ebay,or amazon or anything online shopping.
Won't do online shopping on a boat,not on a train,not even on a plane. I won't shop online sam iam.
Thank you anyway.
Cheers.
Thank you anyway.
Cheers.
By all means keep your head firmly planted in the sand if you must however here's a 1982 EVTM: 1982 EVTM
Well I dug around in my storage and found this manual,it has what I needed inside.
I got my brake lights working,All signal lights and running lights working.
Still can't figure out why no horn,there is power coming into the steering wheel for it and I still need to get my marker lights going again,plus I got the interior light working just before I got the brake lights working,then the interior light stopped working???
I have power to the stereo but when I turn on the stereo power nothing happens,but the test light goes on if I touch it to the stereo case and the test light goes out if I turn the stereo power off?????
