Windshield replacement/upgrade
I have started a quest to sound proof my 2005 4x4 6.0. I have boat loads of Kilmat, Siless closed cell foam and 200sqft of mass load vinyl being shipped now (Jesus $$$$$). I even ordered some cloth tape to use on fasteners, wires, etc. Basically, I'm going full bore here. I regularly make 2k mile round trips and lately the droning from engine, tires, age have all started pushing me past the limit. It is loud inside. Conversations are difficult, especially if you have to talk to the quiet kid in the rear seat. No more...I'm gutting the entire interior, minus the dash because that's a full on nightmare, and I'm hitting every panel, nook and cranny, dang near full coverage with everything and doubling up the MLV in the doors and firewall. Yes it's going to painful, no there's not much room....doing it anyway. I'll try to keep track of how much I actually used and how much you can actually get away with packing into various areas. FYI, You don't really need all THAT much Kilmat type butyl rubber, the biggest benefits will come from the foam and MLV, but you do have to have enough butyl rubber to kill all of the panel resonance. Yes, I'm doing the roof too. If I can pop something off, it's getting treated.
In my researching about why newer cars are so much quieter I learned a lot. Luxury brands even include active noise cancellation via speakers pointed at the source playing cancelling frequencies. Aside from the fact that the panels are better sound proofed against resonance, the biggest disconnect between new cars and Excursions was the addition of "acoustic glass". New cars are typically double paned with a layer of sound dampening material sandwiched in, nylon from what I read. Whatever, it works. Guess who makes acoustic glass for an Excursion? Literally nobody. So I got a little creating and started searching for something to cobble together. Ford did not even start offering this type of glass until 2014. Dug a little further and I confirmed by dimensions and even the rate of curve that Ford used the EXACT same windshield from 2000 through 2016. See where this is going?
Part number DW02022 will get you the acoustic glass with the Super Duty logo blasted across the top the mirror area
Part number DW02060 will get you the acoustic glass with ONLY the dotted sun shading over the mirror area
I bought the Ex from Arizona and the windshield looked as though it was sandblasted. With all of the micro divots, sun glare was literally blinding depending on the angle. Add in the fact that I caught a few rocks that put a few 2 foot cracks in it, obviously I was going to replace it anyway. I figured acoustic glass would cost way more - IT DOES NOT! I did some shopping around and it cost me literally nothing extra where I got it replaced. Other places I looked into, they were actually charging MORE for the Excursion specific labeled glass....
Sound proofing wise, this is a drop in the bucket really. I don't have a standalone decibel meter, I just use 3 different ones on my phone and they all agreed that I started at around 80db at highway speeds and it was still at 80db average with the new windshield. Buy hey, sound proofing/deadening is about the whole package working together. The biggest difference will come with the other materials I ordered. I am still going to do more research and measuring to see if I can find any sort of acoustic glass that I can put in any of the other 6 doors or cargo area...if I find something that will work I'll repost it to here. I'll also post up about the total db reduction and overall feel of the deadeners because the numbers don't tell the full story. You can have the exact same decibel reading, but if the frequencies are all lower it will still "feel" quieter.
Other than the factory sound deadening the 2 areas that need the most attention are the roof and rear wheel wells.
You can make some small improvements to the factory woven air dams in the rear of the front fenders,
same goes for the under hood blanket.
getting rid of the exhaust drone can be troublesome.
Don’t overlook the door seals
DIYMA - Sound Deadener Shootout, v1
DIYMA - Sound Deadener Shootout, v2
https://m.facebook.com/groups/651457188787366/?mibextid=6NoCDW&refsrc=deprecated&_rdr"
ResoNIX Reference Guide
Facebook - "The Deadening"
My process was simple - internet search for the best/most available products, check reviews for everything and rank it completely and subjectively for me, then search for a few hours to find price comparisons for everything. In the end, I went with what I felt was the most affordable of the best options that everyone else seems to be happy with over the long term. Price was an absolute must in the calculation because the amount of material you need for an excursion is double (and sometimes more) than you would need for the typical car soundproofing. I spent a boat load already... I did not go as deep as the threads you shared did nor did I actually go through and try to find out about the butyl rubber chemical compositions of competitors.
In the end the same principles apply. You need to have some sort of a butyl rubber compound against the metal, it's basically every type of foil backed rubber advertised. After that you need to have a decoupling layer, most agree that closed cell foam is the best. Last you need some layering of mass loaded vinyl before you reinstall the carpet. When it comes to dampning with CCF or MLV, it's all about the thickness/weight. There's only so much you can have when trying to put it under carpet, but I'm going to do what I can. The only thing that I'm really worried about is the overall added thickness because if I go too much, then the carpet will never be able to go back down under the door sills, look like @$$ and eventually get torn up by foot traffic. Part of the plan here was to strip the interior and get everything installed then check carpet fitment. If I'm not maxed out, add another layer and so on until I find the max breaking point of materials versus height. In the end I just want to be able to tell people "You can get away with 80mil foil backed butyl, add 157mil CCF and then 1, 2 or 3 layers of MLV". I ordered the 1lb MLV which is 1/8" thick, but I'm sure there will be more than enough room to double up. I didn't want to order 1/4" thick 2lb MLV only to discover that it was too thick and end up wasting time/money. Thus, order small and stack to limit. Most of us don't want to embark on a project like this without knowing at least a ballpark of materials and prices which, again, is the goal to show. This is a bit of a side topic away from the acoustic glass stuff though. I do plan to post the this sound proofing material into a separate thread along with the results. I'm also considering different options for the roof in order to max out the distance between the roof and the headliner without making anything bulge, but I'll worry about maxing that out AFTER I'm done doing the floor because that requires the most disassembly and I don't want have this thing off the road for more than 1 day at a time. I have read some good things about neoprene up there though if anyone wants to chime in.
As it stands right now for the relevancy to this thread, I'm not finding much in the way of glass options for the rest of the truck. I am beyond persistent though...if I strike out in the short term, I'll still be searching for months and just not tell people. What I have found though is that there are some companies advertising the acoustic films that you can apply like window tinting. From all accounts, these are complete garbage with no measurable effects of any sort. Not sure about you guys, but I'm not a fan of snake oil.
Have you looked into what you're going to use under the hood? I'm unsure if Kilmat is the right product as the heat may melt the butyl rubber. I have a hood blanket but want to replace it with something better. Does anyone know what the best product for heat and sound is to use under the hood?
On the roof I know that the butyl might have some issues with sticking in high heat, this is Texas after all... That said, I'm not overly concerned because I'm going to squish things to the max up there and the headliner *should* hold everything up without issue. If there's room, I do have some pretty legit spray adhesive that might allow MLV to be added but I am not sure there will be room even if I only put 1 layer of everything in. Definitely not going to be putting any bed liner type stuff on my roof as this winter I'm planning to weld up a roof rack to go up there and that would kind of wreck those plans.
I do plan to hit all of the AC ducts as well, heard they vibrate audibly if you sound deaden everything EXCEPT the ducts. Reading forums pays off
As far as the hood goes, I'm not 100% sure yet. I have read that Kilmat works and that it doesn't work. It's stated to hold up to 212 and can do short runs at 400, but that seems quite optimistic to me...especially with a turbo only a few inches away. I'm sure I will do something, but we'll see where everything is at once the interior is done. That's a big enough project on its own right now. If I find something that seems perfect I'll post it up.
With the added material in your plan, consider the added weight and clearance for the panels.
post pictures during the process. We love pictures!
Weight wise, the only thing I'm worried about is the vinyl. Even with the 1lb stuff, I had 2 boxes delivered that were 109lbs each... I mean, the adhesive I have is some pretty legit stuff, but holy hell I'm not sure about how well it's going to hold this up on the roof or walls with as heavy as it is.
Thickness wise, I think that everything I ordered should fit under everything ok-ish but yeah, I was NOT expecting the weight.
