A/C refrigerant
Old Oct 26, 2022 | 08:37 PM
HangingInOR's Avatar
HangingInOR
Trailering
A/C refrigerant
What is used as refrigerant in R12 A/C systems?
I have 1988 Bronco that is R12 that I need to repair.
Old Oct 27, 2022 | 06:25 AM
projectSHO89's Avatar
projectSHO89
Yeah, that would have used R-12 refrigerant when manufactured.
Converting to R-134a is the usual path forward.
Old Oct 27, 2022 | 10:53 AM
HangingInOR
Trailering
So what is required to convert to R134A?
Is that an expansion devise change and oil flush? Or can R134A be directly used?
Old Oct 27, 2022 | 04:26 PM
projectSHO89
Flush, change oil. Install higher capacity condenser, if possible. Install service port adapters. Vacuum and charge with r134a, usually around 60 to 70 percent of the weight of the original r12 charge.
That will usually get you in the ball park.
Old Oct 27, 2022 | 06:16 PM
HangingInOR
Trailering
Thats not bad. Great.
No expansion devise change.
Don't know what to do about a bigger condenser.
Old Oct 29, 2022 | 05:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
or just find someone licensed to do R-12 hand have them charge it.
it is still available, and cost the same as R-134A
Old Oct 29, 2022 | 10:28 AM
HangingInOR
Trailering
I didn't know it was still available.
I'll have to call a few shops to see if they still have it.
Old Nov 2, 2022 | 10:41 PM
JamesCarten's Avatar
JamesCarten
4th Gear
There are three replacement refrigerant options for R12 systems: R134a, R401a, R401b. R134a is regarded, by manufacturers and adherents to the Montreal Protocols alike, as the best replacement refrigerant.
Old Nov 3, 2022 | 11:31 AM
HangingInOR
Trailering
I figured R134A would be the current refrigerant to use.
But didn't know if there were any changes I would have to make to the system to use it.
I don't think a bigger condenser is an option.
So I guess I'll pull the compressor, drain the oil, flush the rest of the system, replace the drier, fill with oil and run R134A.
I am a retired HVAC tech so I do have all the tools and know what I am doing.
Old Nov 3, 2022 | 12:04 PM
projectSHO89
I don't recall if a change of size of the FOT is recommended or not. It's been too long... Maybe one of the other folks recalls that detail.
I'd suggest replacing it anyway while the system is open.
Old Nov 3, 2022 | 12:40 PM
HangingInOR
Trailering
FOT ?
The orifice ?
Old Nov 4, 2022 | 05:21 AM
JWA's Avatar
JWA
Originally Posted by HangingInOR
FOT ?
The orifice ?
Yes as in "fixed orifice tube". It seems there are variable orifice tubes available. Not sure if they function like an expansion valve, have heard very little about them in an automotive A/S usage.
Old Nov 4, 2022 | 05:52 AM
tjc transport
i ain't rite
Different size tubes for r12 and r134a
Old Nov 4, 2022 | 11:28 AM
HangingInOR
Trailering
So what size do I need to change to?
Got a part number?
Smaller or bigger?
Old Nov 4, 2022 | 11:34 AM
HangingInOR
Trailering
The orifice takes the place of a TXV but does not vary the flow like a TXV can.
A TXV changes flow based on suction line temperature.
An orifice has a fixed flow rate dependent on the high side pressure.
They do the same thing (separate the low side from the high side) but work differently.
I would think R134A orifice would be smaller than a R12 orifice, not sure.
