Sponsored by: Real Truck
Purchase????
Old Oct 25, 2022 | 05:04 PM
RonC80's Avatar
RonC80
Purchase????
Just got offered an 08 350 powerstroke for $12,000 southern truck(Alabama) I was told full size bed. 160,000 miles. Looks good in the pics I'll have to post in a min. I think that's the 6.4 turbo diesel? What do you all think. I've never owned a diesel but know they go for hundreds of thousands of miles. Is it a good price if the condition is as good as it looks?
Old Oct 25, 2022 | 05:08 PM
RonC80's Avatar
RonC80
Only pics I have so far. Guy just started to work where my wife works
Old Oct 25, 2022 | 05:11 PM
RonC80's Avatar
RonC80
One more pic doubled the one before
Old Oct 26, 2022 | 09:09 AM
Mike1's Avatar
Mike1
Here's what I pulled up on KBB in my area, under Very good condition which is supposedly only 28% of the vehicles offered for sale. So asking 12K is not out of line.
Old Oct 26, 2022 | 09:30 AM
RonC80's Avatar
RonC80
Thanks Mike. I'm going to go look at it this weekend. Might be able to chew him down a bit.
Old Oct 26, 2022 | 09:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Please visit the 6.4L Power Stroke engine forum and get to know the weak points of this engine before you make a purchasing decision.
Old Oct 26, 2022 | 10:12 AM
Antonm's Avatar
Antonm
Having owned two similar trucks (a 2008 and a 2010), it'd be a hard pass for me. The XL truck is a stripper model (so no redeeming interior options there), and the 6.4 PSD is a steaming pile of excrement. Do like five minutes of google searching about the 6.4 PSD before buying one.
As for good things about the truck, the transmission is a solid piece (its either a 5R110 automatics or a ZF6 manual ) and the both front and rear axles are good units (super dana 60 front and Sterling 10.5 rear), but these trucks are let down by the 6.4 PSD, hence the reason a 2002 year model truck with a 7.3 costs twice as much even though its six years older.
Old Oct 26, 2022 | 12:01 PM
99powerstrokedF250's Avatar
99powerstrokedF250
I agree with the above - if you've never owned a diesel, and/or don't have a lot of cash, stay away from the 6.4. It's not a great design, and requires you to stay on top of EVERYTHING to keep it running smooth.
My dad got a good one, his is still going strong with over 200k on it and he drives it daily back and forth to work. It's rusting out though, and he's had issues with the radiator leaking basically its entire life - seems like every 50k the tanks start to leak.
My FIL got one that had gas put in it, had the motor replaced only to find out the trans was also screwed, so he had that rebuilt. He was told he was getting a Ford reman motor...turns out it was a Jasper. 13k miles later we learned it had 5 different diameter pistons when it grenaded itself just driving down the road. Ended up with a rebuild from US Engine Production, also added head studs, and never had another issue for about 50k til he got rid of it for a new truck.
That's just my personal experience with the 6.4. It CAN be a decent motor if you make long drives and don't modify it, but if you want to hot rod it or just make short trips, stay far, FAR away.
Old Oct 26, 2022 | 12:17 PM
Antonm's Avatar
Antonm
Originally Posted by 99powerstrokedF250
My dad got a good one, his is still going strong with over 200k on it .
How sad is it that " a good one" is defined by a diesel with over 200k miles. I mean really, gassers are doing that all the freaking time. A "good" diesel should be over double that and still going.
Old Oct 26, 2022 | 02:51 PM
RonC80's Avatar
RonC80
Thanks all. I've been doing some reading up on the truck and that was what I was coming to the conclusion on. Not a great choice for a diesel truck. I think I'll keep looking and stay with my 08 250 5.4 lariat for now
Old Oct 26, 2022 | 03:00 PM
acdii's Avatar
acdii
When I went truck shopping I excluded everything from 2003 through 2011 due to both of the crapih engines. If you really are thinking diesel, then start with the 6.7 or find a really clean 7.3 1999-2003(early)
Old Oct 26, 2022 | 05:10 PM
Antonm's Avatar
Antonm
Why exclude 2011?, the 2010 model year was the last 6.4, a 2011 would be a 6.7.
Although to be fare I would exclude 2011-2014 6.7's as well because they had that weird turbo with one exhaust wheel and two compressor wheels mounted on one shaft that just didn't work. The 2015's and newer got a more conventional turbo. But then you gotta deal with the CP4 time bomb, so nothings perfect.
Old Oct 26, 2022 | 09:06 PM
acdii's Avatar
acdii
2011, first model year 6.7. I did have a 2012 and it was a good strong running engine.
Old Oct 26, 2022 | 09:26 PM
Jo7.3's Avatar
Jo7.3
My thoughts exactly. My 7.3 has 256k miles and the most in-depth repair I've had to do is glow plugs. My dad has a 2011 chevy 2500 with the 6.0 gas with 280k miles. It burns a little oil but still runs strong. To the OP, as others have said, avoid the 6.4. It is probably one of the worst (if not THE worst) diesels ever put into a pickup truck.
Old Oct 28, 2022 | 06:49 AM
svastano's Avatar
svastano
Too bad that Ford stopped making the 7.3 Diesel!
