Sponsored by: Real Truck
Issue with rear rotors
Old Oct 24, 2022 | 07:02 AM
Gruntsquid's Avatar
Gruntsquid
4wd Low
2000 F 350, extended cab, 7.3 diesel, dually, 6 speed. 102K miles
Got the truck a couple of weeks ago.
Replacing parking brakes since they didn't work. Decided to replace calipers, pads, and rotors due to wear.
Got the drivers side done w/o significant issues.
Doing the passenger side now. Rotor came off without issues. New bearings and rear seal.
Now I can't get the rotor in the axle stub. It appears that the park brakes are too large to fit inside the hub.
I've got the brakes down to the smallest diameter and just can't get the hub to slide on.
Both left and right hubs are identical. The brake shoes came out of the same box.
Any advice is greatly appreciated.
Bruce
Old Oct 24, 2022 | 11:48 AM
Mike1's Avatar
Mike1
Well, if you have the old parts, see if the old hub will go back on, if it does then there's something different about the new hub. If it doesn't then I'd say you probably have a problem with the way the E-brake is installed on that side.
Old Oct 24, 2022 | 12:34 PM
Gruntsquid's Avatar
Gruntsquid
4wd Low
The only thing I've noticed is that the shoes have a bit more brake material than the ones I took off. The inside of the drums measured within a few thousandth of each other. It will "just almost" go on. One thing I'll check when I get back to the shop is the diameter of the inner and outer surface of the drum. It appears to be catching on the shoes as I attempt to get it on.
Old Oct 24, 2022 | 02:39 PM
Djosbun's Avatar
Djosbun
I’ve seen aftermarket rotors with incorrect ID for the brake shoes. Had an AutoZone where every one of them was bad (for a Honda). O’Reilly’s had a different manufacturer with the correct dimension.
You must measure and compare it to the old rotor. If the shoes are all the way in (and installed correctly) then you have a bad/incorrect rotor.
— Dave
2011BlackBeauty
6.7L Power Stroke Diesel
Jan 5, 2014 01:50 PM
A/Ox4
Sep 4, 2012 12:41 AM
capewave
Jan 9, 2007 01:51 PM
DUALLYNOTED
Sep 17, 2005 06:01 PM
SHADOWDUDE
May 5, 2004 08:14 PM
