Engine Compresion
Old Nov 12, 2003 | 12:18 PM
buckeyebronco's Avatar
buckeyebronco
Question Engine Compresion
I was just wondering how do you check the compresion on each cylinder and then determine the overall compresion ration of your engine?
Old Nov 13, 2003 | 03:05 AM
macguyver's Avatar
macguyver
You can't determine the compression ratio from a compression test. You can, however, determine the general health of the engine. If all cylinders read within 10% of the highest reading, that's considered good. Higher/closer is tighter/better. If there's much variation between cylinders, that's an indication of some type of failure and further tests would indicate the problem.
