Rewire Costs
Are you in a major metro area, or a more sparsely populated rural area? Somewhere in between?
The shop rates vary of course, but so do different mechanics abilities and assumptions about time.
And frankly most normal shops will hesitate touch it, or they’ll quote you such a high price that you won’t touch it.
Primarily because they don’t want to touch an old truck where at any moment costs could rise because parts fail, old stuff falls apart beyond their responsibility but it becomes their responsibility because it failed under their watch.
And of course they also make mistakes and break things that they have to pay for, if they could even source a new one.
It’s a can of worms for shops that don’t do it regularly. A truck seems pretty simple to wire, and it is if you know what you’re doing but. But even experienced wire geeks like me would tend to take a lot of time to do it because were scratching our heads at what the factory did versus what the reproduction wire harness does. Or because we decide to change wire routing half way through.
And that’s if you want a reproduction harness, or just a generic aftermarket one.
Speaking of the harnesses themselves, costs of pre-wired harnesses range from $200 to over 1000.
Just for the parts.
Not including every little widget and connector that happens to not come with it. Some of which are made of unobtanium, so you either have to repurpose the ones from your original harness or substitute something more modern.
sorry about the long ramble, but it’s by way of leading up to saying a rewire would probably cost a minimum of $800 by someone who doesn’t know how to quote, to $5000 by someone who doesn’t want to do it.
with maybe 1500 to 2500 being in the middle of all that? Hard to say I suppose, but someone who is in a hurry and on a purposeful mission, and who knows what they’re doing, might actually do it front to back in a single day and charge you under $1000 for the labor plus parts.
That’s hard for me to grasp because it would take me a minimum of a week. But I’ve heard of people getting it done in that amount of time so I had to add that.
Next you could tackle the ignition switch, then the light switch, etc. With each project you take on and complete your confidence will improve. I have seen some work by supposedly competent shops that took longer to correct than it would have taken to do it right. For a full front to back rewire I think some of the prices shown are in the ballpark. Then multiply by 2 for the inevitable problems that will crop up.
Gather all the diagrams of wiring and know them by heart.
If you do this it will be fairly easy. Take out the inst. panel & probably the dash if you can and the new harness SHOULD come with detailed instructions !!! I say the most difficult is knowing what goes where & why so for me time was my most difficult part because I started job to quickly & this causes much confusion & frustration !!! The bundle of wires can be scary, but i cannot stress enough know where the bundle goes you will see everything much more clearly & comfortable you will finish the job
BE PREPARED
OH, LABEL YOUR WIRES YOU HAVE WITH MASKING TAPE , MAKE A LITTLE TAG YOU CAN SEE EASILY . SOON YOU WILL KNOW THE WHOLE SYSTEM
I did mine using the American AutoWire kit. It’s not too complicated although if you have an ammeter gauge you’ll either have a dead gauge or have it converted to voltmeter.
i think the kits assume you are upgrading the alternator. I went with a mustang/Taurus “3g” and had problems with clearance. If I had to do it again I would try a “1-wire” conversion.
I started by removing all of the existing wiring. Beyond knowing where wires go though holes in the body i dont think there was anything to save. I did reuse the headlight pigtails.
laid the entire new harness out on the garage floor to get an idea of what was going on then started working on it. I was done in a few weekends going very slow. I could do it in a day or two now though.
i decided to finish all my wires with electrical tape wrap (the good stuff) but you could invest in some split loom for easier install and servicing.
honestly not many vehicles are going to be as easy to rewire. If you have the space and time it’s worth the cost savings.
