Engine Bore Chamfered Edge
Old Oct 22, 2022 | 03:23 PM
Dalton Tallent's Avatar
Dalton Tallent
I am working on rebuilding a 460 and I don't know if this area on the bore is a problem. It is the outer edge (chamfered edge) of the pistons bore. It is in a couple of the bores. Just need help determining if this is a problem or normal.
Old Oct 23, 2022 | 08:07 AM
mark a.'s Avatar
mark a.
The first thing to do is run a bore gage reading in .0001" through the cylinders and see how much skirt clearance, taper and out of round they are.
Old Oct 23, 2022 | 10:06 AM
Dalton Tallent
The bores are in range. Just want to know if that marking is original or wear. It seems machined.
Old Oct 23, 2022 | 08:15 PM
DaveMcLain's Avatar
DaveMcLain
That chatter stuff is normal as are the gigantic chamfers on some of the bores. It won't hurt anything simply because it is way above the ring travel.
Old Oct 23, 2022 | 08:18 PM
Dalton Tallent
Awesome. That was my understanding. Just thought I would run it by you guys on here!
Old Oct 23, 2022 | 08:27 PM
DaveMcLain's Avatar
DaveMcLain
With the wide 5/64ths rings they can be helpful with something like a 1mm ring they can be a nuisance.
gSwift
Oct 10, 2022 08:04 PM
hi-jacker
May 1, 2019 07:01 AM
King-bRanch
Ford Truck Parts for Sale
Dec 20, 2012 08:30 AM
