Sponsored by: Real Truck
Front axle
Old Oct 22, 2022 | 08:50 AM
Randy777's Avatar
Randy777
Front axle
Quick question. I have a 2004 4X4 Super Duty 6.0
(I am changing fluids but can't remember what fluid to use in front axle and transfer case. Rarely use four wheel drive but have not change front axle or transfer case in a while.
Old Oct 22, 2022 | 09:25 AM
user 195474726373's Avatar
user 195474726373
No owner's manual?
Old Oct 22, 2022 | 10:23 PM
Boaterguy's Avatar
Boaterguy
80W-90 (or 75W-90) in the front case, and per Ford, OK to use Mercon LV in the transfer case, even in your year. Do yourself a favor, order a gasket from LubeLocker for your diff, no silicone to use, no waiting, and no leaks. Added benefit, it's reusable for under $30....
Old Oct 23, 2022 | 07:22 AM
bajaphile's Avatar
bajaphile
Yep, love my LubeLocker!
Old Oct 27, 2022 | 07:39 PM
00t444e's Avatar
00t444e
75 or 80w90 in the front axle, regular cheap Mercon rated ATF in the transfer case.
Old Oct 28, 2022 | 03:51 PM
Antonm's Avatar
Antonm
Valvoline sells a synthetic transfer case fluid that says its intended to replace the old Ford XL-12 (which Ford no longer makes) that was the original transfer case fill. I use it all my Ford transfer cases, works fine.
Old Oct 28, 2022 | 04:10 PM
00t444e's Avatar
00t444e
Mercon ATF was the original fill, Ford XL12 didn't exist back in 04.
Old Oct 28, 2022 | 05:36 PM
Antonm's Avatar
Antonm
I guess ford switched to recommending XL-12 in 1997-2007 at some point later then. The below is copy/pasted from torque King (formally known as Quad 4x4), they're usually pretty on top of their stuff. Looks to me like when Ford switched to mercon V they just kept making regular mercon and relabeled it XL-12.
*****For the 1997-2007 Model Years, most Ford Factory Shop Manuals list Mercon as the recommended transfer case fluid. Ford introduced Mercon ATF in 1987 and Mercon is the recommended fluid for most 1997 to 2007 4x4 Ford transfer cases. Mercon was superseded by Mercon V which is NOT recommended for use in transfer cases so Ford was recommending XL-12 for use in 1997-2007 transfer cases which has been replaced by Mercon LV. As of May 2019, an old Motorcraft web page still lists Mercon LV as Not For Use in Transfer Cases, but the most recent LV page specifically states LV is now for all transfer cases.
kevin.ford-trucks
Apr 24, 2022 10:01 AM
rastymus
2015 - 2020 F150
Feb 18, 2020 04:30 PM
comadvan
Mar 1, 2014 10:39 AM
dieselguy22
Oct 8, 2005 07:54 PM
ranger714
1983 - 2012 Ranger & B-Series
Jul 3, 2005 07:52 PM
