Ideling
Old Oct 23, 2022 | 12:11 PM
Sport45's Avatar
Sport45
I think he’s saying he lets the oil warm to 100° before driving.
I don’t idle more than 15 seconds or so before putting it in drive myself. I get in, start the truck, then take off easy after fastening my seat belt and checking the mirrors and gauges. If it’s cold enough that I need a jacket I’ll start the truck with my key fob as I’m walking towards it. Oil is over 100°F by the time I get to the highway.
Old Oct 23, 2022 | 01:05 PM
tradosaurus's Avatar
tradosaurus
I always idle when refueling my truck.
My opinion is less off/on cycles can only be good because of less cycling of parts.
Old Oct 23, 2022 | 01:19 PM
Overkill2's Avatar
Overkill2
Originally Posted by cj45lc
And the starters ain't cheap, if I'm gonna be just a few minutes running in to get a coffee or whatever I let her idle. I do idle after towing until my oil temp hits 195 or so, never leave until the oil temp gets to 100.
I really wish I had an EGT gauge like I did in my 7.3 , I never shut down until it got below 350 & that seemed to work pretty good for 380k miles.
I read here to let EGT1 get to a low of 400 degrees. If it's higher than that, I usually let it drop below 400, to at least 375 degrees, sometimes to 350. But I do like it to be below 400 degrees to be honest.
As to EGTs, you should get yourself a digital monitor or monitor with your phone or an old device with FORscan or Torque Pro.
Old Oct 23, 2022 | 07:23 PM
cj45lc's Avatar
cj45lc
This is what I should do & probably will pretty soon
Old Oct 24, 2022 | 07:10 AM
q5 dave's Avatar
q5 dave
It's just a truck. Y'all have too much mechanical sympathy! I get in and drive. Idle 30 seconds max to put on seatbelt and put phone in cupholder. Only idle while fueling if my wife is in the truck. Or unless a regen just ended. Granted I barely tow, but now that we're back to + $5 a gallon it's only running if it's moving!
Old Oct 24, 2022 | 05:16 PM
Dirthawg2.0's Avatar
Dirthawg2.0
I agree with g5 dave everyone is overthinking it. I idle the hell out of my truck for my own comfort. I also start and stop the engine probably a dozen times a day. Don't idle it after pulling because usually by the time I'm off the highway and park it's had time to cool down. I do let it run on high idle in the winter months for about 10 minutes, once again for my comfort.
Old Oct 24, 2022 | 05:42 PM
senix's Avatar
senix
not so much idle
Old Oct 24, 2022 | 06:34 PM
riverratrusty's Avatar
riverratrusty
This I don't do... my theory is it creates air in the fuel and maybe the conditioner doesn't get it all out before it makes it to the CP4 pump and increases wear. Is this just paranoia or could there be some logic here?
Old Oct 24, 2022 | 09:50 PM
cj45lc's Avatar
cj45lc
Hmmm that is an interesting thought
Old Oct 25, 2022 | 06:25 AM
tradosaurus
I would think that would be true regardless of whether the engine is running. Also vapor from the fuel tank goes to a charcoal canister to be scrubbed.
Also I only refill my fuel tank when it reaches about half the tank.
Old Oct 25, 2022 | 08:17 AM
KodiakF250's Avatar
KodiakF250
I never run any vehicle while fueling for other reasons, but I agree, this is interesting. The stream of diesel is very likely churning the fuel in the tank with air bubbles, and since the fuel pump is running, it may suck in some of that air. Just depends on the location of the pump and how deep the air bubbles are driven If you're not running the engine, the air bubbles should float up and out of the fuel pretty fast since diesel is just a fluid. Then when you start the engine after fueling, no air bubbles. I never thought about this.
Old Oct 25, 2022 | 10:52 AM
riverratrusty
And to be clear, I am not saying a single time of fueling up with the engine running blows up a CP4 pump. I'm just wondering if over time, the air that does get in there is hard on the system. Combine this with diesel that is not as slippery as we would all like and maybe draining the fuel filter every 30 days checking for water gets even more air into the system and puts a strain on things. Rest assured if it is 118 degrees and the wife, kids and dogs are in the truck I might leave it running while I fuel it up
Old Oct 25, 2022 | 11:18 AM
  #28
Overkill2's Avatar
Overkill2
All this talk of air bubbles in the fuel is the very reason I bought an Air Dog -- to get rid of entrained air in our fuel that is created by the very motion of the truck's movement. With the amount of pressure these CR engines are running, air is no good... Still needs to be installed. Hopefully soon after my DPK kit is in.
Old Oct 25, 2022 | 11:50 AM
  #29
HRTKD's Avatar
HRTKD
I'm inclined to say that air bubbles aren't likely to be an issue. As stated a few posts earlier, air bubbles go up and the fuel pump draws from the bottom.
Old Oct 25, 2022 | 12:16 PM
  #30
Dirthawg2.0
Draining fuel and or water from the fuel conditioning module does not introduce air into the system. It's a low point drain and would require draining the entire separator before air is introduced into the fuel lines heading to the rails. At that point the fuel system would need to be re-primed in order for the engine to start.
The re-priming process is the important part, if not done correctly it can lead to wear on the HPFP.
I would agree. It shouldn't be any different than driving around with a half tank or less with the fuel sloshing back and forth. Is aeration of the fuel an issue? I don't have an answer for that but I think it's less of an issue due to Ford using a lift pump between the fuel tank and the HPFP unlike RAM and GM.
I replaced my factory 26 gal tank with the S&B 56 gallon tank. The factory tank was just an open rectangle with a low point at the fuel pickup. The S&B tank has a low point at the fuel pickup as well but also includes baffles that surround that low point to reduce fuel sloshing around while in motion.
