I have 03 f150 4.2.6cyl & horn beeps when I turn stearing wheel left only does not beep when straight or turning right, turn signals , radio , & cruise control all work..please help what could the problem be???
You have a short in the column wiring or the horn contact plate is faulty
A tech is going to want to remove the Airbag / Horn contact and interrogate it for failure, inspecting and interrogating the wiring at the same time
There are used horn contact plates for sale all over ebay and that is a clue
Don't see much trouble with the sliding contacts (clocksprings) for your issue
