67 highboy trans swap
Old Oct 21, 2022 | 01:24 PM
Jhawck's Avatar
Jhawck
1st Gear
Hey all I am switching my 67 250 highboy to automatic c6 transmission my question is as follows is the splines on the manual output shaft the same as an automatic? So that I might be able to swap the yolks around?
Old Oct 23, 2022 | 06:22 PM
73 Crew's Avatar
73 Crew
To convert to a C-6 I believe you need to find a FE truck C-6 with a bolt on yolk for a u-joint and short tail shaft housing. Just to be clear your truck has a divorced stye transfer case 3 drivelines not a married type with 2 drivelines? If tour truck id a divorced type I'm not sure that the intermediate drive shafts are same in manual and automatics so may need a new one built. Car C-6 have long tail shaft usually with a splined slip yolk for the drive shaft. Your original 4-speed transmission should have had a u-joint type bolt on yolk for the intermediate drive shaft. I hope this is useful information regarding your swap.
67F250RET
Mar 8, 2013 09:10 PM
vincel1965
Nov 20, 2012 09:50 AM
1975MudRat
Jun 10, 2012 10:09 PM
AndysFords
Offroad & 4x4
May 4, 2008 03:28 PM
fordsrgrt
Dec 5, 2006 09:17 PM
