Need help
Old Oct 20, 2022 | 07:34 PM
Jimgodlove's Avatar
Jimgodlove
3rd Gear
Need help
Hi guys, I have a 2006 f250 6.0. Truck died while making a right turn. No it will crank but not turn over. Since then, I have replaced batteries, Boost Seloniod, ICP and wiring harness, crankshaft position sensor, air filter, bath fuel filters and nothing. Before that replaced all injectors and glow plugs. Had a/c coil serviced before this happened. Noticed the MAP behind the coil was not plugged in. Plugged it in, $1,000 in parts later then it started, but took a while too start. Next day is when I got it started. Drove it home and it died. A few days before it would die coming to a stop at a stop light. Then crank back up after a few tries. I'm thinking of checking FCIM and IPR next but broke as a joke now. Any suggestions?
Old Oct 20, 2022 | 08:17 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome. I see you`ve found the 6.0L Power Stroke Diesel2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van forum. Post in there for help.
Old Oct 21, 2022 | 09:29 AM
2020FordRaptor's Avatar
2020FordRaptor
Welcome to the forum!
Old Oct 24, 2022 | 11:17 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Looks like you found your way to the "6.0L Power Stroke Diesel" forum. They'll be able to help you out!
Welcome aboard!
Truckdream
17
Dec 9, 2021 06:09 AM
Bad truck89
Jul 7, 2021 12:00 PM
Alfred Pennyworth
New Member Introductions
May 18, 2021 11:37 PM
Slingmud
Jan 1, 2015 08:47 PM
