Hi guys, I have a 2006 f250 6.0. Truck died while making a right turn. No it will crank but not turn over. Since then, I have replaced batteries, Boost Seloniod, ICP and wiring harness, crankshaft position sensor, air filter, bath fuel filters and nothing. Before that replaced all injectors and glow plugs. Had a/c coil serviced before this happened. Noticed the MAP behind the coil was not plugged in. Plugged it in, $1,000 in parts later then it started, but took a while too start. Next day is when I got it started. Drove it home and it died. A few days before it would die coming to a stop at a stop light. Then crank back up after a few tries. I'm thinking of checking FCIM and IPR next but broke as a joke now. Any suggestions?
Hi and welcome. I see you`ve found the 6.0L Power Stroke Diesel2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van forum. Post in there for help.
